Woodland Hills, CA
Blocking MFI Ports
I am putting together a hot rod 2.4 motor with Webers and I would like to know what the preferred method for blocking the off the MFI ports is in the heads? Can I just fill the small orfices from inside the chamber? Are there any other pitfalls I should be aware of? Thanks
Old 02-21-2009, 10:36 AM
Max Sluiter
Flieger's Avatar
Sell them and find some heads that have no MFI holes. Those MFI heads are too special to ruin.
Old 02-21-2009, 01:32 PM
Porsche's Love-em Live-em
Blocking MFI Ports
Brass Pipe thread plugs or bolts at a hardware store.
Can I just fill the small orfices from inside the chamber? Other than welding them shut no. To much work. I would Just plug or get different heads.
Prevent pitfalls? Teflon tape on plug threads to prevent air leaks.
Good Luck!
Old 02-21-2009, 01:52 PM
Home of the Whopper
I flowed 2.2 carb and mfi heads a couple of years ago. I can't remember the exact numbers, but the carb heads flowed a lot better. The injector port causes a lot of turbulence. I would try to plug the holes flush with the inside somehow. Maybe a long bolt and grind it down?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 02-21-2009, 02:42 PM
Zeke's Avatar
Long bolts don't work. It's a pipe, or tapered thread, IIRC. Unless it's a race engine, I wouldn't worry about the performance loss due to any turbulence.
As mentioned, if you haven't re done the heads yet, trade them. Or, you could weld the holes up.
Old 02-21-2009, 03:29 PM
Jeff Jagusch's Avatar
Try EBS?
I could be wrong, but I have a mtoro that has very nice allen head plugs, my guess is that the guys at EBS sell them?
Jef
Old 02-21-2009, 03:35 PM
are they bigger then the 930 air injection plugs?
Old 02-21-2009, 04:24 PM
Zeke's Avatar
12mm X (x) X 1.5 if that helps.
Old 02-21-2009, 04:28 PM
PMO sells them
Robert
Currently Porsche less (but the wife has 2)
Old 02-21-2009, 06:57 PM
Home of the Whopper
Normally I would agree that a street car just doesn't 'need' the same as a track car. However, the flow was reduced pretty significantly. Personally if I could spend the same time and money plugging the port and get ~10% more airflow, it would be a no brainer.
Old 02-22-2009, 08:45 AM
Woodland Hills, CA
I have a set of 2.0 heads, but they have smaller valves and ports. So I am to assume that you are speaking of the 2.2 heads as an equal trade in terms of valve and port size?
Old 02-22-2009, 06:55 PM
Austin, Texas
roaddog84's Avatar
I ordered a set of "mfi plugs" from Tom Butler (Tom1394 racing) for $20 plus shipping. The problem from what is see is there is too narrow of a shoulder on the case without damage, but on the mfi injectors they are tighten about 1 inch above the case.
Tom won't be back until 3-8.
I don't see why something along these lines would not work either.
george
Old 02-26-2009, 09:48 PM
