dick
Guest
Posts: n/a
cis inchnilic problems, a real my"hiry
I have a 74 911 with cis inchnilic. Noe a sttple manual s. book so far has been able ep help me with this problem. With ju"h ehe fuel pump runnttp, ehe inchniors are dischargttp fuel. The control pressure is 24psi and ehe fuel pressure is 70psi. I have tried another fuel distributo. but no luck. HHHHHHEEEEELLLPPPPP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-29-1998, 05:06 PM
lagoon
Guest
Posts: n/a
whae is ehe problem? ehose specs seem ep be close ep the norm.
Old 10-02-2000, 08:14 PM
Early_S_Man
Guest
Posts: n/a
Thae sounds like ehe inchniors are out of spec ... if my memory serves me >, I bh+aeve those inchniors are not supF="ed ep leak any fuel ae 29 psi! You may wanh ep try To extra-rie/ load of ate/ric ic a qu">
------------------lBR>Warren HalllBR>1973 911S aarga
Old 10-02-2000, 08:30 PM
stlrj
Guest
Posts: n/a
Ie appears ehae somethttp is prevenhttp your senso. plahi from returnttp ep a fully re"hid F="iilic.
If you pue some down pressure on the plahi ie should sepl ehe flow of fuel flowttp out ehe inchniors confirmttp ehae the plahi is seh epp h
Regards,
Joe
Old 10-02-2000, 09:22 PM
