Very nice. The AL button (early car) really makes it look good. The dual gauges make for nice balance.
volt and CHT looks great.
are those gauges larger that for 2.25 ga ? |
Mark |
dB meter for your multiple subwoofers? :p
I had this volt/AFR gage made by Bigmark Design and am happy
/Users/jeffclotz1/Pictures/iPhoto Library/Originals/2008/Roll 80/DSCN4573.JPG |
FWIW I added boost and EGT guages to my Subaru (2.0L turbo) and while I watch the boost, I don't pay that much attention to EGT... maybe if I was modding the engine / exhaust it would be useful. |
jcoltz,
Where did you find the Volt/Mixture gauge? |
http://www.newvintageusa.com Mark |
So a combo Boost & AFR guage in the clock hole is doable? That would be very useful. I would swap out my 934 boost gauge for that combination.
http://i1.ebayimg.com/02/i/001/22/6d/ff8f_1.JPG |
DSouth, I used the gage along with the LC-1 wideband controller from Innovate. there was a little calibration fussing, but it works fine.
how about this.....911 Driver’s Air Ventilation Kit
Replaces the factory heater/ventilation system under the cowl and blows generous amounts of air to the driver. The air comes out through the clock hole. A bolt-in installation. 911 ‘69 to ‘89 041100............................................ ....................$231.45 |
Built in GPS?
It's about the right size but described as square. However, I googled it and the casing is supposedly "high impact Polystyrene" so should be easily cuttable. *dreams of flyer's helmets, goggles and cries of "Chocks away!", "Tally ho, chaps!"* :D |
Hey Milt here's what I did with my broke clock.
http://forums.pelicanparts.com/uploa...1236303865.jpg |
Geeee, gotta big enuff or more obvious turbo gauge?
http://www.914world.com/bbs2/style_e...fault/slap.gif |
no its not as big as the stock boost gauge that replaces the clock but I'm trying.
Gud fer you.....
| All times are GMT -8. The time now is 05:15 AM. |
