2.7 vs 3.6
what is the weight difference between 964-3.6 & 2.7; engine only, thanks
76' 911s Signature Edition |
AutoBahned
what 2.7??? CIS, RS, ??
do search for more
sorry, the one I have "76 911s, was just obsessing, if my engine, were to blow sky high, What would I do ...3.6 swap or rebuild to 2.7RS, weight is definitely a factor to me, & I haven't done some mods , like ssi ....because they wouldn't work with transplant ...actually , I think what I really want to know is how much horsepower & weight can can a "76 handle without giving up that light responsive feel it has & having to change out a lot of components, I really like it the way it is, just would like a little more horses & the 964 engine looks like better way to get it, so I was asking in a too simplistic way what the weight difference is, thanks for responding...RWebb
76' 911s Signature Edition Last edited by enzo1; 03-01-2009 at 01:04 PM.. |
wow, there is a lot of difference, I didn't know how much!
AutoBahned
the wt. differences are mostly in the induction & exhaust systems.
a dollop of wt. was added in the transition from Mg to Al cases (2.7L to 3L SC) P AG went on a major wt. saving expedition when doing up the 993 motor - I think I collected the info from Frere and Aichele and posted it some time ago.... if your motor blows sky high, you can always swap in a Wankel... |
trying to learn the search thread better, i always do a search 1st , but it says try again , a lot; so I get frustrated & just post what I want to know, lately i've been searching certain knowledgeable persons threads, such as yourself......takes more time but learn a lot, i'm trying to get my mind around the wankel.... naww can't do it, I like nightmares better, other stuff is boring----like golf.... or fishing, mowing the lawn, or HONEY DOs
AutoBahned
for knowledgeable persons, use these terms:
Grady Clay jpnovak Sherwood Bill Verburg John Walker's Workshop Steve Weiner and others... Last edited by RWebb; 03-01-2009 at 02:44 PM.. |
I started with John Walkers, almost got through it, Why couldn't he have shop here, I will start from top down, and won't forget yours
Randy,
I can't quite figure out your table for a 75-77 911s. Is it 386 or 400 lbs? Paul. |
Here are the factory weights, these are as equipped ready to install w/ all ancillary components inc/ AC, PS, SAI
993RS 487.2 w/ single mass flywheel/clutch/pp 993RS 507 w/ dual mass flywheel/clutch/pp 993 n/vr 510 w/ dual mass flywheel/clutch/pp 993 nvr 492.8 w/o flywheel/clutch/pp 964RS 484 w/ single mass flywheel/clutch/pp 964 C2/4 525 w/ dual mass flywheel/clutch/pp 964 C2/4 507 w/o flywheel/clutch/pp 930 /20/26 483 930 /21/25 485 930 /16/17 441 930 /10 419 930 /03-/06, /13, /15-17 441 930 /07-/09/19 419 mag case engine weight ~25# less than the same in aluminum trans weight depends on type, material and lsd or open, w/or w/o mounts 901 trans w/ equivalent case material and diff type is ~9-10#s less than 915 here are some that I've weighed using electronic corner balance scales my mg case 915/44 w/ open diff weighed 95# my al case 915/67 w/ lsd & cooler weighs 122# g50/05 w lsd 146# g50/10 w/lsd 150# my g50/30 w/ lsd 156# g50/32 w/ lsd 155.5#
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-02-2009 at 07:55 AM.. |
Great info!
3 restos WIP = psycho
Wow, my 2.3ST replica motor looks like it will have the same HP/weight ratio as a 3.6
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
AutoBahned
not clear what the source of the variation is... to add to Bill's post, IIRC the factory spec. for trans. wt. includes the starter - not sure if I recall right but there is an old post on this... |
AutoBahned
so... I guess if A/C is std., then it will be included in the wt.
on the old cars, A/C was a dealer installed option, so would likely not be included in the wt. but if A/C was a factory option..... |
(the shotguns)
Great question. At what point in weight/hp do you change the character of the car? 2.7RS spec sure looks good right now.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Thats what I was thinking. then you see guys like Bill ,going the swap route, I just wanted to ask the question & see what the BIG dogs think, under my specific application
Administrator
The numbers you usually see on the later engines are misleading. With a 3.6, for example, you immediately ditch about 100 pounds when you get rid of the dual mass flywheel, stock exhaust, heater blower and power steering pump for a swap into an earlier car.
Bill Verburg has listed some weights that were more apples-to-apples than the ones you usually see for 'fully dressed' engines. Quote:
And as Bill put it: Quote:
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
thanks for the reply ,Jack, LOVE your car, but you have built a rsr, "the gold-plated Porsche", if u will....I don't want to have to change my car to suit that much horse power & weight, in other words I like fun littlle 'sleepers' ,I guess the real ? is: torgue 'which I really like & stability(engine)......I keep seeing people get their cars all screwed up with the stability of the car...I keep bouncing back & forth, 40# sure isn't much, I could probably lose that much by summer, very compelling
Weight will be the least of your concerns re 2.7 to 3.6 t/p you absolutly have to have a big(or 2 big) front coolers. Next issue is the above mentioned rear wheel dilemma. w/o body mods I'd suggest a nice 3.2 w/ headers & chip 7" 944 x16 Fuchs all around(maybe 944 8 in back) 215/45 & 225/45 tires, adjustable sways to tweek the balance.
thanks bill, I will probably revisit this post a lot,I just hate to ditch the 2.7, cause it runs fine just would like a little more juice & have emotional attachment to car, I may have to get over it, honestly I haven't given the 3.2 enough thought, that sounds like a perfect choice, thanks again
76' 911s Signature Edition Last edited by enzo1; 03-02-2009 at 06:36 PM.. |
