Tad, amazing as always man. I just got my doors in the other day and now on to the front half of the cage (don't want to cut up $$$ doors) and then on to the air jack system.
I really want to see you car in person man. I vote you finish it, then drive it to next years 12h of Sebring. This way you can stop at my house and I can see it. ![]() Take care brother Chris |
FUNFGRUPPEN |
Fuel pump is a Weldon pump 2015A
Project hit 5th year
February marked my fifth year on this project and the list is getting alot shorter finally. Got all the water lines run for the intercooler and radiator, tank and pump. Need to run it and test for leaks.
![]() ![]() Need to make raised cover with duct lines going to the naca ducts in the quarter windows. Main Item Remaining: Transmission: Hookup cv joints, clutch cable,omega spring, shifter linkage. Engine: Fabricating the piping from engine to intercooler and turbo Wiring: Using the ISIS intelligent multiplex system, solid state, less weight and wire, can do away with multiple relays and its very adaptable. Install time is shorter and much cleaner after the fact. Over the last couple of years it was always the goal to get the car running by summer. Obviously I did not accomplish that but it kept me plugging along and this summer definitely seems like it might really be possible. |
Decided to weld up a different bracket for my center oilcooler. Did no have good access to the oil lines for repairs. Made the bracket where it can fold out, good access for the lines etc..
![]() ![]() Bumper and valence remove as one piece for loading on trailer. Got the ISIS multiplex wiring system today. Deciding on locations for the mastercell and the two powercells. Will post the wiring install when I get further into it. ![]() Mastercell ![]() Front powercell ![]() ![]() Rear powercell behind seat |
ISIS multiplex system install
Got started with the electrical system install this last week. The locations did not change much from my first thoughts except for the front cell which I made a bracket and center mounted, easier access.
![]() Rear Powercell ![]() Front Powercell: you can see location for 10 fuses, 5 on each side, same on rear powercell. ![]() Mastercell: The brain of the system, tells the powercells basically what to turn on and off. ![]() 8 gang switch panel, switch functions are programmable. ![]() For a race application 8 switches is more that adequate, lightweight and only 4 wires to operate the functions. Small yellow cable from mastercell to switches. The whole ISIS system in the box was only 14lbs. ![]() Megafuses: Megafuses protect the system. The large red wires are the power supply to the powercells. ![]() Megafuse 4 ga wire feed needs to be as short to battery as possible. ![]() Total of six wires on each side. Ten are for items to be powered and a black wire on each side goes to ground. Each items negative wire will go to ground as well. This is not a lot of wires to deal with and once hooked up and loomed should look nice and neat. Will post more after I finish the front wiring and get to rear powercell which will be bulk of work to be done. |
coolcavaracing.com
Cool stuff. How do you program the ISIS system?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Awsome work Tad! keep it coming
FUNFGRUPPEN |
To really set up the system the way you want and be able to make changes to the standard system you buy the incode programmer $180. Company website ISIS Intelligent Multiplex System - Automotive Wiring Harnesses, Car Wire Harness, Engine Wiring Harness, Auto Wiring Harness, Truck Wiring Harness, Car Wiring Kits.
coolcavaracing.com
Thank you for the link. A bit confused, this would not replace the main harness from the DME to the engine as well and the main engine harness will it?
Tad, the car looks great. You're making great progress on getting the cells mounted. This will be a very clean install when it is finished.
We'll get you some suggestions today on wiring your disconnect switch. Jay |
Nice fab work and great looking car.
Do you have any details on the red circled area in the pic below? Did you fab that up yourself? How does the ducting work and where is the drain for water? Looking for some type of venting.draining system for my car. Thanks -
Jeff |
coolcavaracing.com
Jeff |
Vent encloser is one from smart racing and yes I think they are no longer in business. Krogger you were asking about the DME and the ISIS system. The ISIS system would not replace your DME.
Porsche 934 935 reinforcement sheets
Hi,
made some sets of copies for my project of a pair of original 934 / 935 reinforcement sheets for he luggage compartment, see pics. Currently in fabrication ist the front aluminium cross and the fiberglass fuel cell pan, pictures will follow..... Benno ![]()
Hi Benno, very nice fabrication. So are you building a 934 or 935 replica or restoring a wrecked 934 or 935 to a replacement tub? Interested to so more of your project. TRE motorsport was making the fiberglass 935 fuel cell cover for the two front fuel cells if you need a source for that part.
Hey Tad,
I wanted to show you the amount of wire that we removed from Jim's 1999 996. We had this in a fish tank at our booth at SEMA last year. When he installed ISIS in his Porsche, he netted more than 30 pounds of weight reduction in the car. ![]() I'll get more pictures of the car from him when he gets it back. Jay |
Jay, here is the wiring that came out of my car. Have not weighed it but I would not be surprised if its similar weight savings as Jim's 996
Sweet build!!!
Do you have wheels picked out yet?
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
