Gearbox (915) gasket sets
Fairly straightforward question. Does it make sense to replace all gaskets on a 915 when installing a new clutch set? Tx
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 03-10-2009, 01:08 AM
Almost Banned Once
sc_rufctr's Avatar
If your gearbox is leak free there's no reason to do this.
If however you're a tinkerer like me you could open up your gearbox and check the internals. Then you would have to change the gaskets. (I'm joking)
The 915 is a robust gearbox but it doesn't suffer fools.
(I'm not implying you're a fool)
Old 03-10-2009, 01:27 AM
Slumlord
Porsche_monkey's Avatar
Maybe the rear gasket and the little gasket on the plate, they are easy to do.
But if it's not leaking, why bother?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 03-10-2009, 06:27 AM
KTL KTL is online now
Schleprock
KTL's Avatar
The only gaskets you should bother with on the transmission "while you're in there" are the radial seals for the shift rod and the input shaft (behind the release bearing guide tube). Also look at the crankshaft seal while you have the trans out. If none are leaking, leave them alone.
Kevin L
'86 Carrera "Larry"
Old 03-10-2009, 07:50 AM
Tx for the input guys.
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 03-10-2009, 09:08 AM
Slumlord
There is also a guide tube modification you might want to make.,Drill a hole in the bottom and make a silicone dam, in case the seal goes it will save your clutch.
84 Cab - sold!
Old 03-10-2009, 12:13 PM
that dog is sleeping, why wake it up?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-10-2009, 01:34 PM
Slumlord
Dogs can leak while they sleep.
84 Cab - sold!
Old 03-10-2009, 02:22 PM
Almost Banned Once
sc_rufctr's Avatar
lol....
Old 03-10-2009, 03:49 PM
