Carrera787's Avatar
Porsche Crest 911 Carrera ('86) - Handling Upgrade Suggestions?
Hello fellow brethren.
Can anyone provide some straight advice. I have an '86 3.2 Carrera Targa, and she's well maintained and cared for yadder yadder yadder. Her handling is good, but I wish to tighten up her handling a touch.
To put you in the picture, she lives on 16" Fuch wheels (and I plan to keep it that way), 245x55's on the rear, 205x55's on the front, with her OEM shocks under 10k miles / 2yrs.
I'm not seeking track handling, just simply tightening her up a little. I plan to next fit strut tower braces and Targa braces to begin the process, so please advise as to the most cost effective ways to improve her handling 'tightness'.
Any advice would be appreciate brothers! (and sisters of course).
E43 Coupe
C43 Coupe
Boxster S
911 Carrera Targa
Cayenne S + ML350 + 924S (RIP)
Old 03-11-2009, 12:47 PM
Bill Verburg's Avatar
20/55 & 245/45 x16 are a good size to have, dividends will come from maxing the wheel width to 7 & 9.
Bilstein hd's are an excellent choice for shocks.
Shock tower brace ok, but I'd pass on the targa braces
sport seats will hold you in place a bit better.
lower/corner balance and sport alignment are mandatory
Bill Verburg
Old 03-11-2009, 12:56 PM
Carrera787's Avatar
Porsche Crest Thanks!
Thanks for the FAST reply Bill... Appreciated!
I'll look into Bilstein hd's, and I'll drop the idea of the targa brace.
You mention "lower/corner balance and sport alignment are mandatory".
Excuse this dumb quesiton, but can you guide me to this?
E43 Coupe
C43 Coupe
Boxster S
911 Carrera Targa
Old 03-11-2009, 01:11 PM
At the track = great day
ChkbookMechanic's Avatar
For corner balancing you can read this: http://www.elephantracing.com/techtopic/cornerbalance.htm
Lowering is normally done during / right before the corner balance (since corner balancing will cause the car to change its ride height a little).
You should be able to get a sportier alignment and corner balance at a good Porsche or racing-type shop.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 03-11-2009, 01:22 PM
madmmac's Avatar
Best in the area for your lowering, alignment and corner balance needs......http://www.trulineseattle.com/.....the Bellevue shop.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 03-11-2009, 01:33 PM
Stock ride height(distance between the t-bar center and wheel center) for an '86 Carrera is 108mm +/-5, you can certainly do 113 w/o issue and even lower if you use an inexpensive washer kit to rasie the steering rack.
for performance you will want to max caster to ~ 6* 20'
min toe to just on the pigeon toe side of 0
max camber to ~-1 - 2( thats about all you can get w/ stock spindles & ball joints
in back
stock is 16+/-5( center of t-bar to center of wheel) but you can go to 7mm w/o issue
camber -1 - 2 to match front
car should have a slight nose down stance
forgot to add, adjustable swys are great too.
Bill Verburg
Old 03-11-2009, 01:37 PM
Carrera787's Avatar
Porsche Crest
Excellent article 'ChkbookMechanic' - Thanks!
Thanks too Mitch for the shop Bellevue shop links - Excellent!
Thanks for the great data Bill - Superb!
Thanks fellow brethren!
E43 Coupe
C43 Coupe
Boxster S
911 Carrera Targa
Old 03-11-2009, 01:41 PM
