Bill Verburg's Avatar
Big favor to ask of those w/ Recaro seats
I'm looking for hard data on the variations in sidemounts
Sooo, if you have a minute and can measure the vertical distance between the lowest mounting hole and the bottom of the side mount, front and rear, that would be helpful
Something like this
If it's easier you can measure to the bottom of the slider, just identify if you have the 3mm spacers used for the seatbelt mounts
Format
sidemount front rear
BK9066 92.2 87.25
Would love data on any and all sidemounts that you use in your car also it would probably be best to id the sseat and car. I'm sick and tired of guessing and taking some salesmans word.
Bill Verburg
Old 03-16-2009, 09:58 AM
group911@aol.co's Avatar
Bill
I'll get some measurments from a Speedster seat tomorrow.
I also have a pair of non Porsche SPG's and 996 GT2 seats. Do you want them measured as well?
Bob
Thanks,
Bob
group911@aol.com
Old 03-16-2009, 10:03 AM
Originally Posted by group911@aol.co View Post
Bill
Bob
yes, any and all, just ID what combo it's from. Trying to get info from the suppliers is maddening.
Bill Verburg
Old 03-16-2009, 10:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
jstein has an SPG on recaro mounts. I'll ask him to measure his.
Kevin L
'86 Carrera "Larry"
Old 03-16-2009, 10:54 AM
AutoBahned
RWebb's Avatar
all Recaro seats, Bill, or just the ones that are currently sold?
Old 03-16-2009, 10:57 AM
Tom '74 911's Avatar
Here, Here! I am in the process of fabricating my own for this very reason. I have bought 3+ sets, trying to find one that suits my purpose and got fed up. A database of this info would be a great resource. Good on ya Bill V.!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 03-16-2009, 11:50 AM
Bye, Bye.
Scooter's Avatar
Bill, I will get a measurement from my Speedware mounts this evening for you.
Elvis has left the building.
Old 03-16-2009, 12:44 PM
jsveb's Avatar
Hi
Seats are Pole position SPG.
Side mounts are original Recaro Steel items.
Front distance is: (lower part of hole to slider) 100.4 mm
Rear distance is(lower part of hole to slider) 90.4 mm
regards
Jesper
Old 03-16-2009, 01:02 PM
Thanks Guys! All seats all sidemounts
Bill Verburg
Old 03-16-2009, 01:30 PM
Originally Posted by jsveb View Post
Hi
regards
Jesper
PP and Profi SPG and Profi SPG XL are marketed as different seats over here, though they have been changing the names. Somtimes the SPG is called Profi, SPG XL > Profi XL etc. The Profi SPG XL is the only one w/ the large holes for shoulder harness
Is that the Recaro universal steel sides or perhaps the PP specific sidemount(Recaro7202451?)
SPG XL on left PP on right
the SPG looks like the SPG XL but is narrower 395mm at the seat base
Bill Verburg
Old 03-16-2009, 01:40 PM
David's Avatar
I just installed PP's with the steel Recaro side mounts. If I can remember this evening I'll get some dims.
Old 03-16-2009, 02:06 PM
There are at least 2 different Recaro steel sidemounts
1) universal
2) PP specific
Bill Verburg
Old 03-16-2009, 02:13 PM
David's Avatar
I'm not sure which side mounts I have and the part numbers are covered by the seats.
The front is 4-1/4" from the bottom of the rail side to the center of the lowest hole.
The rear is 4" from the bottom of the rail side to the center of the lower hole.
Old 03-16-2009, 06:07 PM
jsveb's Avatar
Hi
I'll see if I can find the apropriate data for you -tommorrow that is. (mine are PP)
Jesper
Old 03-17-2009, 01:47 PM
First seat factory Speedster seatsThis picture rear of same seat.
This picture front bolt on factory GT2 996 seat. Also, these brackets are aluminum.
Rear bolt 996 GT2 seat
Front to rear GT2 996
Non Porsche Recaro
Non Porsche Recaro rear
Non Porsche front to rear
Another factory Speedster seats but the front holes are slotted.
Thanks,
Bob
group911@aol.com
Old 03-17-2009, 02:55 PM
Group911 especially and to all other s as well, THANKS!
Bill Verburg
Old 03-17-2009, 03:17 PM
David's Avatar
Those Recaro mounts look significantly different than mine. They're lower, but I wonder how they line up with stock rails and PP width? I'd like to lower mine about 1/2".
After years of installing kart seats, this was the easiest seat install I've ever done. I mounted the passenger seat to the body rails and the driver seat on Recaro sliders. The Recaro slider offer a lot more for and aft movement.
Old 03-17-2009, 07:06 PM
arrivederci's Avatar
Need any more? I have an SPG in the car that I could measure up...
- '72 911T
- '81 911SC Euro
Old 03-17-2009, 07:34 PM
Bye, Bye.
Scooter's Avatar
Speedware Mounts:
Front: 5.5 centimeters
Back: 7 centimeters
Old 03-18-2009, 08:22 PM
