cis to carbs wiring question
Have removed the cis from my 82 911 for a carb conversion. Want to clean up the engine compartment wiring as much as possible and eliminate as much of the cis wiring that I can. I have searched the threads and I have not found much other than leaving everything as is. Is there a wiring diagram available that I can gain access to that might help? Any and all help would be appreciated.
Old 03-22-2009, 04:21 PM
al lkosmal's Avatar
ssrodder,
Pelican has the wiring diagrams for the 82SC. Follow the link below. hope it helps.
Al
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
RGruppe #669
http://www.x-faktory.com/
Old 03-22-2009, 04:24 PM
Eliminate wiring to the WUR, AAV, Cold start Valve, Thermal time switch and all the other CIS stuff. You can clip these and cap them or you can eliminate them all together from the harness plug. Depends on how far you want to go right now. If you remove them from the harness plug then be careful when you take the plug apart as the wires will fall out and you can have a hard time getting them right again. The only wires you should have left going over the top of the engine is the starter wires, the alternator wires and reverse light switch wires. These can all be compiled into one single 1/2" wire conduit.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-22-2009, 04:29 PM
Wire pin outs at the harness plug for 80SC;
79sc Main Wire Harness Pinout Needed
Old 03-22-2009, 04:33 PM
