Anti-Seize on Spark Plugs
Would it be a bad idea to use copper anti-seize on spark plugs? I know about the debate about electric conduction but my concern is the possibility of corrosion between competing metals. Copper and aluminum are not friendly in contact with each other on roof flashing. Would this be a similar problem with copper in contact with the spark plug and cylinder head?
Thanks, CL
CWL '86 Carrera Coupe '88 Carrera Cab '02 525i Sedan |
I use it and haven't seen any problems.
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
I use graphite.
Dan |
I always use an anti-seize although at this time my can is not copper, the grey made by ???
Regards |
Hi Chris, FWIW,..I've used copper-based anti-seize on every plug installed in an aluminum headed engine for 34+ years without any difficulties or issues whatsoever. For me, this has prevented problems when extracting the old plugs and has not affected the operating temp range. Its critically important to use very little and ensure that its spread evenly across the threads. The "Devil is in the Details",...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Just don't overtorque the plug- the antiseize acts as a lubricant which will allow you to put a lot more preload on the plug and stress the threads. "Modern" engines don't have a separate helicoil insert for the threads.
'66 911 #304065 Irischgruen 96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
NEVER use the silver/gray anti-seize!!!
Keep the Shiny Side UP! Pete Z. |
i use nothing, as per porsche's recommendation. no issues either.
Just curious, what's wrong with the silver / gray permatex product?
Thank you, Doug
1971 RSR - interpretation |
Not that I am going to change but I would like to hear the reasoning. Regards |
Autodidactic user
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
AutoBahned
the reason appears to be contamination problems re the O2 sensor or catalyst
likely OK if you have an older car with MFI or carbs - I usually use anti-sieze on my carb'ed motor |
Autodidactic user
same aluminum head, O2 sensor or not.
Czar of C.R.A.P.
Didn't porsche also change the torque spec from an actual foot lbs to = so many degrees of turn past seated? Only would work with new plugs.......
If the original torque spec was made with nothing on the threads then some form of lubricant could really mess with the specs......
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
I always routinely used "the silver-grey" lubricant (sold by Champion in the case of aviation usage) on aircraft engine plugs, and so did every A&P mech that I knew. Flat four-, six- and eight-cylinder air-cooled aluminum Lycomings and Continentals are obviously very similar to 911 engines. this has been standard in the aircraft business for at least half a century.
Obviously it's to be applied sparingly and carefully.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
YMMV.
1984 Targa |
Fel-Pro Anti-Seize Lubricants
INDUSTRIAL GRADES NICKEL ANTI-SEIZE Suitable for use with stainless steel, this copper-free compound is recommended for chemical, waste water and sewage plants, and environments that require a clean, inert lubricant. Resists strong acids, chemicals, and temperatures to 2400° F. SILVER GRADE General purpose, silver-colored. Smooth texture makes it suitable for protecting fine threads, snug slip-fits, and other closely-mated parts. C5-AŽ link to tds and msds Copper-based formulation protects parts to 1800° F. Our original anti-seize lubricant, C5-A is still our most requested product for protecting nuts, bolts, fittings, and ensuring easy assembly and disassembly of metal parts. Meets MIL-A-907. Source:http://www.newmantools.com/felpro.htm
72' 911S Coupe Last edited by chrisgo17; 05-19-2009 at 01:35 PM.. |
No problems,.....as mentioned torque application needs to be applied correctly. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Scott B: Seabee? Stinson Voyager??
