Wevo or Harget 915 shifter
I am about to purchase a shifter for my 915 gearbox to be use on a '73 RSR clone that will be used 90% on the street. Does anyone have experience with both shifters and have a strong recommendation one way or the other?
Thanks for your help.
Bob
Old 03-26-2009, 08:09 AM
sudo apt-get purge 930
equality72521's Avatar
This has been asked to death. Have you searched for this yet? If not, I suggest you do. You'll find many opinions on both.
--clutch-monkey
Old 03-26-2009, 08:25 AM
scottb's Avatar
If you want to retain something of a stock look, go with the Wevo.
1984 Targa
Old 03-26-2009, 10:32 AM
moneymanager's Avatar
Don't forget the Rennline unit, which some find superior to both.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-26-2009, 10:39 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Agreed. That's what I went with after comparing all of them. My deciding factor was stock appearance, adjustability in shift reduction (20% or 33%), plug-and-play, and extended handle. I have never tried any of the others though. I am VERY happy with mine. It doesn't shift as smooth as a modern car, but it's pretty close.
From what I have heard nothing beats the Harget as far as feel, but you have to do some pretty significant interior modifications, and it sticks out quite a bit.
1981 SC ROW Coupe
Old 03-26-2009, 10:48 AM
Where do you find the Rennline unit? I've been on their site and I don't see it.
--clutch-monkey
Old 03-26-2009, 11:02 AM
Almost Banned Once
sc_rufctr's Avatar
Don't you mean the "Rennshift"? This is the one I have.
http://www.rennshift.com/
Old 03-26-2009, 03:27 PM
Go Speedracer, go!
Ditto.
1981 SC ROW Coupe
Old 03-26-2009, 03:32 PM
Yup.
jhtaylor
santa barbara
Old 03-26-2009, 03:42 PM
e p slick's Avatar
I have had both and liked both. Sorta like going to bed with a red head, blond of brunette. Each has unique features. Then there is the tall girl, short girl, thin girl, medium sized girl, fat girl. They are all designed for one application - shifting round, up and down.
Buy both - sell one.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-26-2009, 04:07 PM
No wonder I couldn't find the Rennline one. So, slick, which one did you like and why?
--clutch-monkey
Old 03-26-2009, 05:58 PM
Send a message via Yahoo to algs911
In installed the WEVO along with WEVO's shift coupler and new bushings in my '86. A little expensive, however WELL worth the money in my opinion. Reverse is locked out when shifting from 5th to 4th, nice piece of mind. The WEVO unit is so good it makes the 915 box almost feel like a modern box! A Porsche mechanic drove my car once and questioned the year, he thought it was a G50 box.
It's the single best improvement I've done to my '86.
Alan
Old 03-26-2009, 06:44 PM
Senior Advisor
James Brown's Avatar
just go with a tiptronic!
08 Cayenne Turbo
Old 03-26-2009, 10:36 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
what about the fabcar shifter? does it compare?
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 03-26-2009, 10:41 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
They are all good shifters but Ive used the WEVO and I cant imagine anything being 'better' than it.
Old 03-26-2009, 11:05 PM
I use the wevo "classic" that looks completely stock.
I've never used others so can't compare.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-28-2009, 01:15 AM
How long does it take to install a wevo?
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 03-28-2009, 07:06 AM
Crusty Conservative
silverc4s's Avatar
Rennshift for my money. Renew coupler and all bushings at the same time.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 03-28-2009, 08:26 AM
Installing the WEVO took about 2 hours, if memory serves me correctly. Adjusting the coupler took the most time. It's a pretty straight forward and fun install, if you're in to that sort of thing. Adjusting the coupler wasn't too bad either, really.
Al
Old 03-28-2009, 12:27 PM
