sudo apt-get purge 930
Power to manual windows, searched
Has anyone actually converted power windows to manual windows and not just talked about it? I want to do this and would like to hear from someone who can tell me exactly what is needed and any pointers. I am going to put RSA doors panels on and would like to make the change while I'm doing the job.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
"O Gruppe 13"
wrestling it currently......not that i wanted to, but the door, I bought, was PW and my 68 has MW. Will record progress......
G-Man 89 964 C4 86 930 |
Pretty straighforward. You need the the channels that correspond with your lifts. Glass will interchange. All the bolt holes and holes for the handles are there. Much easier than manual to electric.
My understanding is I have the parallel lifts and the associated channels. If I were to get the manual parallel lifts and channels from say a 1978-1985 I should be good, correct? I believe they changed the lifts in 1986.
I've read in the past that weight savings are minimal, if that's what you're after.
Weight issue is only a portion of it. Mostly it's because I want the simplicity of it.
