shall I rebuid or get new caliper pix
hi there
so I finally got the calipers out, cleaned them but looking at them I wonder if I should get new ones
Is the inside should look like this
the piston look fine to me
look at those pics
and give me your advice please
AB
Old 03-29-2009, 01:00 PM
DarinB's Avatar
I would clean it up and rebuild it. If your not getting any brake fluid seepage, then your fine. It's only about $15 for the seals, so why not give it a try?
Darin
1995 993 - Black/black, RS splitters, brake ducts
1978 SC - "Toyo Spec" - Completed
Old 03-29-2009, 01:26 PM
Max Sluiter
Flieger's Avatar
They look great to me. I have seen photos of much worse.
Old 03-29-2009, 01:51 PM
abit off center
cgarr's Avatar
Are those steel or alum pistons?
______________________
Craig
G2Performance
Old 03-29-2009, 01:55 PM
they seem to be steel
AB
Old 03-29-2009, 02:04 PM
Rouxzy's Avatar
At this very moment I'm rebuilding mine. I'm using a dry green scotch brite and it is shining everything up. I wish mine looked as good as yours before I started. I'm glad I decided to rebuild when doing a brake job because it looked as though the fronts weren't working as good as the backs. In fact one of my front pistons was a bit&* to get out. But after some time with the scotch brite it looks pretty good.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 03-29-2009, 06:15 PM
vash's Avatar
those look great! rebuild away.
poof! gone
Old 03-29-2009, 06:16 PM
djpateman's Avatar
That looks better than average in my experience. I hope that is not a dimple on the piston, but even so it looks small enough that is should not be a problem; no more than half the width of the O-ring seal in my estimation. The green scotch brite pads are very good for cleaning brake parts. Use a Q-tip in the O-ring seal groove to get out all the crap. Scrub the bore outside of the O-ring seal groove as best you can; this is where most build-up occurs that interferes with piston action. Rinse well with alcohol, and blow it clean with compressed air. I always use brake assembly lube when rebuilding, but I am not sure where you can get that stuff these days.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-29-2009, 06:46 PM
ruf-porsche's Avatar
Rebuilt my calipers last summer, but I went with stainless steel pistons.
Old 03-29-2009, 07:52 PM
Nine9six's Avatar
If the weight in your hand is unsure, a magnet will tell for sure.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-29-2009, 07:54 PM
thanks every one
AB
Old 03-30-2009, 06:23 AM
defcon65's Avatar
Just rebuild them; the kits are cheap and available here. You will need silicon brake assembly grease, a compressed air source, 400 grit silicon carbide paper, brake cleaner spray and a selection of C-clamps and small chunks of hard wood to seat the dustboot retainers. I found it to be an easy and satisfying DIY project. I also put speed-bleeders on it for simplified bleeding. If they're really filthy you can soak them in kerosene for a couple days to loosen the crud.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 04-01-2009, 09:09 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Look fine to me. Just new seals and you're good to go.
Old 04-01-2009, 11:19 AM
(the shotguns)
berettafan's Avatar
wow i wish mine looked that good.
Old 04-01-2009, 12:09 PM
Both of my front dustboots were in shreds - as a result, the part of the cylinder on the outside of the O ring seal had gunk on them as well as the pistons. After working on the pistons, they look as good as new - the cylinders look great on the inside of the O ring but a bit stained on the outside.
They seem to work a lot better now than before the rebuild.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 04-01-2009, 01:14 PM
