A level floor is a flat floor. You need is a flat floor.
Check tire air pressures. Might be good to run the pressure up high to take a bit of the tires spring rate out of it.
Just some guesses.
Love the bottle jack with a pressure gage plumbed in.
Old 03-30-2009, 09:02 AM
Just some guesses.
cycling has-been
bkreigsr's Avatar
this is really splitting hairs.
If I get to within 120 lbs of where I want to be, it's good, If I get to within 80 pounds, its perfect.
The best shops consider the car being 'corner balanced' if it gets within 50-100 pounds of target.
These rudimentary tools should only be used for proximates.
Or not.
I mean, if you are set up like Penske, I agree with all the above:
Old 03-30-2009, 10:05 AM
