Rattling Fuchs Center Caps--how to fix?
I can hear my center caps rattling while driving --any easy fixes?
1980 911SC Targa 3.6L |
Rtv !
wtf is Rtv?
Go Speedracer, go!
Keep driving until they finally fall off, then buy a new one. I had one that was doing that, and before I had a chance to find a fix it, the rivets let go and it fell off. New ones aren't that expensive.
They are riveted to the backing plate that fits in the rim, so I don't know how you would get RTV in there without dismantling. Maybe a small spot weld on the rivets would fix it? RTV is high temp silicone gasket material.
1981 SC ROW Coupe |
If the backing ring and cap (whole cap assembly) is loose or rattling, this worked for on a few sets of Fuchs. very simple.
Take cap out and find little dimples on the retaining ring that hold the cap in. They may be covered in grim and hard to find but they are there. Using a small punch, make the dimples a little bigger (renew them) by tapping them with hammer and punch from the inside of the retaining ring. Gently... not too much or you wont get the caps back in. Just a little bit will be fine. That tightens them up. Get it so the caps will only fit back in with a good 'slap' and they wont go anywhere. |
abides.
I'm not sure what type of caps you have, but when mine were rattling the face was loose on the retaining ring. Here's what I did:
Remove centercap. Make sure face is clean, and lay face down on a smooth piece of wood. With a hammer and center punch, make a dimple in each of the nubs that come through the retaining ring. This will make them spread out and tighten against the retaining ring. Voila! Edit: I see you have an SC, which probably has the ring type like mine, so I think this should work for you.
Graham 1984 Carrera Targa Last edited by gtc; 03-30-2009 at 10:09 AM.. |
i used JB weld on mine.
2 out muffler with SSI's if that doesn't work then try headers and megaphones.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
RTV= Room Temperature Vulcanize
Silicone RTV which dries in a plastic/rubberized state
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Born to Lose, Live to Win
is the emblem loose? i noticed my emblems coming loose from the caps one day. i used JB weld
1983 911sc 2025 Chevy Colorado ZR2 |
Thread Tools | |
Rate This Thread | |
