GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Steering Bushing near RACK
WHAT ARE THE SYMPTOMS OF A WORN BUSHING ON THE TOP OF THE STEERING RACK/ BOTTOM OF THE STEERING SHAFT?
CANT THINK OF THE NAME OF IT AT THIS TIME.
Old 04-03-2009, 09:29 AM
SteveinTO's Avatar
Does the steering wheel move "in and out?" Or "up and down?" Or can you turn the wheel without moving the rack? Check the u-joints and connections by removing the inspection cover in the front trunk, turn the wheel and feel for what's loose. There aren't that many parts to go wrong.
Old 04-03-2009, 10:07 PM
I'm assuming you're talking about the bearing that's in the smugglers box. Play in the steering wheel has nothing to do with that bearing. On my SC, this became worn to the point that it allowed the shaft to move enough that the universal joint would bind. Not good! Replacing it returned everything to normal.
Old 04-04-2009, 06:56 AM
