Super_Dave_D's Avatar
Ugly Wheel Wells, What would you do??
My wheel wells are really looking bad and its driving me crazy, first of all I don’t know if the under coating that is on this is even factory but its peeling off and there is nice red paint underneath. Under the red, is the factory stone guard so I am starting to think the black was applied by the PO.
What would you do to freshen up the wells? I power washed and tried to knock off the black and I got off all of the loose stuff and tons of dirt!! How can I get the black undercoating off without destroying the paint and stone guard. The picture shows where I am now. You can see where I got a little overzealous and took off some paint.
I have Wurth beige stone guard / Guards paint and the gun but I really don’t want to go that far. I also have some black Wurth undercoating and im tempted just to re-shoot it.
What would you do or have you done? Is this factory applied?
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 04-03-2009, 08:39 PM
al lkosmal's Avatar
undercoat
i'd undercoat with Wurth high build undercoating.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 04-03-2009, 09:29 PM
Looks like dirt, just clean it up. More original that way.
Old 04-03-2009, 09:36 PM
Almost Banned Once
sc_rufctr's Avatar
The black stuff is factory applied. It's a sound deadening and protection coating.
Some RS and RSR models didn't have this applied to save weight...
How to make it look better?
Option 1. Strip it all off for that clean under body look... (lots of hard work)
Option 2. Touch up the bare areas with POR15 or similar and then cover same areas with body colour (using a mini foam roller) ... When these coats are dry reapply the sound deadening and protection coating.
Does anybody know what the factory stuff is called? Can you still get it? What's a suitable replacement?
I think it was called "Preolin" or something similar.
- Peter
Old 04-03-2009, 09:38 PM
no its not dirt
2015 Audi S3
Old 04-03-2009, 10:38 PM
No need for anything but some work. Take the wheels off and start off with some heavy duty degreaser and a brush. Let that work to get the major crud off. Simple green works if you want to go with something gentler. Follow up with some solvent of choice (Kerosene, paint thinner, etc) to get the more stubborn stuff off. After your down, you will find the wheel wells are finished very nice. Mine looked similar to yours prior to cleaning. It was some sort of waxy, tar caoting that was on pretty good but came off with solvents. Try those first incase it isn't paint.
Old 04-04-2009, 05:13 AM
One man's sealer / over-spray and grease is another man's dirt.
Test your cleaners. On one car I used something like simple green or an orange product and got some discoloration.
If it is the tar that is around the strut plate, a heat gun works well on it.
Old 04-04-2009, 05:53 PM
Dixie Region R Gruppe
w21055's Avatar
regards,
Al
+1 on Al's suggestion.
Heres mine.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 04-04-2009, 06:00 PM
Southern Class & Sass
Dixie's Avatar
The black stuff is not factory applied. The wheel wells on 911s were shot with Stoneguard and then painted the same color as the body. The black is a common detailer's "touch".
I bet a bit of soap, a bristle brush, and a little elbow grease will take the black right off.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-05-2009, 06:41 AM
Almost Banned Once
sc_rufctr's Avatar
Are you sure? I always thought it was applied at the factory. I had to use turpentine to get it off when I needed to. (Front Weimeister anti roll bar install)
- Peter
Old 04-05-2009, 07:17 AM
maxnine11's Avatar
I am going to guess it is a combination of brake dust/rubber/road grim embedded in the original cosmoline.
It was on my 993; can't remember what the SC looked like.
max
Old 04-05-2009, 07:28 AM
Seems like a good pressure cleaner would get that stuff off. Steam and pressure would be even better. It could be old cosmoline which is like a sticky wax.
You'll have to get under there and take some time spraying, wear safty goggles, you'll be wearing alot of the crap when you're done.
Or just go over it with new puff cans of black undercoating spray. If you do that, buy name brand stuff like 3M or Wurth so it goes on nice and lasts.
If you do it in your driveway, drive the car onto a tarp to collect the overspray first.
Old 04-05-2009, 09:03 AM
Two words, "Simple Green". Spray it on and watch the oil/dirt crud melt off. Don't dilute it, use full strength. It works miracles!
It's true, it's true...
Oh, don't forget a brush.
Rinse/wash with hot water when finished.
Yea that's it.
85' 911 Coupe: Rebuild complete.
Old 04-05-2009, 09:04 AM
Red Clubbie's Avatar
I also had similar dirt and gunk on mine when I got it.
All the pictures I have seen of wheel wells are the car colour, so I also don't think the underbody deadener is factory applied.
I started using degreaser but found the best method was to use straight kero on rags and plenty of elbow grease. Use plenty of different sized brushes too to get into the tight spots.
I continued onto the underbody and used the same method.
It's time consuming and dirty work, but the results are worth it I think.
Cheers,
Geoff.
1984 911 Carrera.......
Old 04-05-2009, 04:07 PM
Zeke's Avatar
I agree. I've seen the undercoating on some cars and I suspect the reason it doesn't stick in places is because of what the factory DID put on under there after the car was painted and assembled.
Old 04-05-2009, 04:14 PM
