compression vs valve adjustment
when i first recieved this 1977 911 2.7 , the first thing i did was a compression test, well all the cylinders were between 150 and 120 number 3 was the highest, well the car wasnt running to good so i then did a valve adjustment and it still was running bad , well me and a friend just did another compression test and now number 3 has 60 pounds , could the valve adjustment cause me to lose that much compression?
If it was done incorrectly it could. Valves that are set without enough clearance will be damaged.
1989 Carrera 3.2L in 993 bodywork |
