Brad w's Avatar
1980 SC Flywheel resurface $$
Called Napa to have the flywheel resurfaced and was told $60 because there are two surfaces to machine down. Is this true and is $60 a fair price?
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 02-02-2008, 01:53 PM
Virginia Rocks!
VaSteve's Avatar
I paid $60, but IIRC it was only 1 surface. I think that's the going rate.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-02-2008, 02:10 PM
Capitalist and Patriot
911Freak's Avatar
There are 2 surfaces on the flywheel that are important:
1. the surface/face that comes in contact with the clutch disc
2 the outer surface where the starter ring is bolted to.
It is common for the face to be "resurfaced" or machined, and most good shops will check the outer surface to ensure the starter ring gear mates to the flywheel smoothly.
In some cases this requires machining...
Check your Bentley Manual and you will see the 2 areas defined..
Good Luck!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 02-02-2008, 02:11 PM
sjf911's Avatar
Paid $25 at our local Clutch World.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-02-2008, 04:08 PM
Tom '74 911's Avatar
Timely post for me. How does one know if the flywheel needs resurfacing? My engine and trans. are out of the car and one of the "while I'm in there's" is to install a new clutch. The flywheel feels pretty smooth ie:no grooves that are obvious - is resurfacing something that one just does regardless?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 02-02-2008, 04:13 PM
the starter ring slips over the pressure plate, so it doesn't relate to the flywheel. one surface only. most of them are warped, so be sure to tell the guy to stop, if the grinder only contacts one side of the flywheel every revolution or you will have an annoying vibration from the imbalance.
206 637 4071
Old 02-02-2008, 04:17 PM
Blanco's Avatar
clutchman.com charged $40.00 here locally. Did it in 15min.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 02-02-2008, 04:41 PM
AutoBahned
RWebb's Avatar
some shops will surface the crank mounting area & then match the clutch area to that
Old 04-10-2008, 10:17 AM
Throw it on the ground!
I got clutchman's contact info from a local shop. Are you satisfied with their work? Did you take it to him or did he come to you? I was told he is mobile with the equipment on his truck.
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-22-2009, 07:03 AM
AutoBahned
RWebb's Avatar
Tom - the spec. booklet & shop manual give you the specs. you could measure with right tools & ability or give a copy to the machinist
Old 02-22-2009, 10:55 AM
Thanks,
Tom
Anyone have an answer to this? Do you always resurface with a new clutch, kind of like new brakes...
83 SC
Old 04-04-2009, 09:58 PM
AutoBahned
RWebb's Avatar
Let me try again.
No.
the spec. booklet & shop manual give you the specs. you could measure with the right tools & ability, or give a copy to the machinist you take it to.
Old 04-04-2009, 11:25 PM
I recomend using a new flywheel instead of resurfacing an old one, particularly if there was any clutch chatter associated with the old clutch.
FWIW,
JR
Old 04-05-2009, 05:06 AM
AutoBahned
RWebb's Avatar
always a good solution if ya got the scratch...
I bought a used SC one and resurfaced it for my '73 with 3.2L motor.
Old 04-05-2009, 10:27 AM
JMHO,....
I never resurface flywheels as it effectively shortens the life of the clutch and my customers would be quite displeased if I did such things.
If its damaged or warped,.....I replace it. If it simply needs a cleanup, Scotchbrite works wonders for that.
Do it once and do it right and you'll never regret it.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-05-2009, 10:55 AM
id911T's Avatar
I second the scotchbrite method. I've done this on a bunch of cars where the flywheel was straight and in spec. Just a normal clutch replacement where it wasn't "run to the rivets". The scotchbrite breaks up the surface polish and the clutch breaks in nicely. Works like a champ!
Stephen
GruppeB #906
1970 911T
Old 04-05-2009, 01:55 PM
