Aluminum "S" Caliper Question
Is there any difference in the Aluminum Calipers that came on the '69-'73 year cars to the '76-'77 turbo cars and on to the 911SC's ?
Are the castings the same ? Are the rebuild kits the same ? Are the pads the same size for all ?
Thanks for the information,
Woody
Old 05-05-2009, 07:41 PM
early turbos are the same I think the sc used m calipers
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-05-2009, 07:42 PM
Shaun @ Tru6's Avatar
there were 2 versions of S calipers, early and late, which are beefier on one side.
Left came off a 75 US Carrera, Right came off a 69S. Wondering is the later version was better, especially on a normally-powered early car. There must be a 300+ pound difference between a 77 Turbo and a 69E, which the caliper on the left are slated for.
Tru6 Restoration & Design
Old 05-05-2009, 07:57 PM
Thanks Shawn, your posting really shows the difference in the casting of the caliper body.
One would assume the larger casting will allow for greater heat transfer ? Agreed ?
It also appears the pad size is the same ?
Thanks again,
WP
Old 05-05-2009, 08:44 PM
Max Sluiter
Flieger's Avatar
Old 05-05-2009, 11:10 PM
Thanks again,
WP
a little extra heat xfer, yes, and I think the later may be a little stiffer.
Old 05-06-2009, 04:41 AM
SC-targa's Avatar
Some early SC's came with aluminum S calipers. The installations appear to have been random.
This was probably just to allow Porsche use up the leftover inventory, since the Turbo's from 78 on had transitioned to the 4 piston calipers, the S calipers were no longer needed.
Regards,
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 05-06-2009, 05:55 AM
Bill Verburg's Avatar
Regards,
Jerry Kroeger
No SC ever came w/ S calipers. The factory changed to the A's starting w/ the '76 Carrera 3.0. The last use of S oem was on the '77 930
Bill Verburg
Old 05-06-2009, 07:48 AM
Thanks for the help, guys, this make the ID very easy ....................
Hope to see any and all Pelicans @ Monterey in August,
Old 05-06-2009, 09:09 AM
