Smile 930 trans going into 1984 911
Hello im going to need some advice i am going to install 1987 930 trans into my 1984 911 has anybody done this im looking for info on the axles 930 has bigger trans flange / can i use 1985 axles ? thank to all Bryan
Old 04-14-2009, 12:52 AM
Monkey Wrench
Spede's Avatar
Why are you doing this? You're going to have to do some major surgery on the body unless you've had the bell housing shortened.
Are you running a stock 3.2? I'm not sure if it has enough "oomph" to run a turbo tranny.
Old 04-14-2009, 01:52 AM
930 trans
im running a supercharger 3.4
Old 04-14-2009, 02:14 AM
beepbeep's Avatar
unless you are using a Carrera tub I believe it's easiest to use stock Carrera halfshafts (with integrated non-detachable outer CV's). They have correct Cv diameter. SC CV's have smaller diameter and won't fit 930 flange. They are also weaker.
When we were fiddling with 930-box-into-SC thing we bought complete Carrera halfshafts and they fit.
Regards,
Thank you for your time,
Old 04-14-2009, 03:00 AM
thanks i have a carrera 1984 but the iner flanges are smaller than the 930 outputs they might be sc ones have a nice day Bryan
Old 04-14-2009, 03:09 AM
lin7310948's Avatar
axles
i use 85 to 89 carrera axles in my early 911 with a short bell 930 gearbox. of course i am using aluminum trailing arms. the axles and cvs have held up well to almost 600 chp and 550 ft/lbs torque. seems that you would be better to get a 76/77 930 gearbox or shorten the one that you have.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 04-14-2009, 05:24 AM
Thanks LIN sounds like you have a real monster of a ride im looking at my opt, i love to work on my car so this is very fun, thanks to all have a great day Bryan
Old 04-15-2009, 01:22 AM
