Throw it on the ground!
Replacing shaft seals on G50?
Looking for tips replacing main shaft seal (999-113-326-41-M204) and shift shaft seal (999-113-404-40-M204) on G50 tranny on upcoming engine swap/ clutch project. Search indicates possible special tool required on main shaft seal removal under TO guide tube here:
G50 Input Shaft Seal Leak
Have not been able to find much on the shift shaft seal replacement on the nose end of the tranny using the search function.
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 04-18-2009, 06:16 AM
aj88cab's Avatar
Mark,
If the tranny is out of the car the shift seal it is a piece of cake. IIRC, I believe the shift seal has a flange on it, carefully pry it out with a screwdriver, then install the new one by tapping in with a suitably sized drift (piece of pipe, pvc, or similar).
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 04-18-2009, 08:26 AM
Originally Posted by aj88cab View Post
Mark,
Andrew
Thanks Andrew, sounds easy. Have you replaced the main shaft seal too? Any issues getting the old one out?
Mark
1987 911 Coupe
Old 04-18-2009, 08:29 AM
aj88cab's Avatar
Haven't done the main seal...yet! Sorry can't help with that one.
Old 04-18-2009, 08:30 AM
I did them both last fall and it is pretty straight forward. You will need to use some sort of seal removal tool on the main. When prying, be sure to protect the case as it dings easily. Note the position of the old one before removing. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 04-18-2009, 08:42 AM
