Throw it on the ground!
Location of 1987 brake booster vacuum line in engine compartment?
Trying to locate the brake booster line and connection point in the engine compartment. Is this it?
Center of photo below cruise servo with hose clamp. Hose runs left then down and out of engine compartment
Nylon connection nipple right center of photo
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 04-16-2009, 06:03 AM
KTL KTL is offline
Schleprock
KTL's Avatar
That is it. Underneath the car near the trans crossmember it is the fat hose near the center of the chassis next to the clutch hydraulic line and also the throttle rod
Kevin L
'86 Carrera "Larry"
Old 04-16-2009, 06:20 AM
Thanks. I've searched for a part # and cannot find one. Do people just use generic vacuum hose from a big box auto parts store to replace?
Mark
1987 911 Coupe
Old 04-16-2009, 06:26 AM
KTL KTL is offline
Schleprock
KTL's Avatar
If you use generic hose, it might collapse/squish easily. I'm sure there's nothing super special about the hose that Porsche used for this application, other than the fact that it's VERY sturdy hose. So make sure you pick a hose that has a thick wall to it.
I looked in the parts diagrams and the hose is found in the Main Group 6 (Wheels, Brakes) and in Subgroup 4 (Brake Fluid Reservoir/Brake Master Cyl.). The part number you want is below part number 16 in the list. Looks like the hose sold by the length is 999.181.022.50 which is 11.8mm (call it 12mm) OD, 4mm ID hose.
https://techinfo.porsche.com/techinfo/pdf/en/catalogues/E_911_89_KATALOG.pdf
Kevin L
'86 Carrera "Larry"
Old 04-16-2009, 06:47 AM
