making my 911 quieter
Car is a Carrera 3.2, SSIs, SW chip, Monty 2in 2out muffler.
Problem is I need to quieten the car down due to "domestic circumstances" Any idea what to do to significantly reduce noise at idle and the drone at cruising speeds? Any suggestions welcome. RG5 |
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
2 in 1 out muffler should help
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Yes see if you can block a tail pipe off that will drop sound levels considerably
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I have almost the same engine set-up and I use a Triad "street" muffler for around-town use. Very quiet and inexpensive. 2-in, 2-out version.
http://www.triadwestperformance.com/ My only caveat is that the guy that makes the Triads has been difficult to catch in the past as I don't think he does this for a living.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Try putting a removable cap on one pipe.
Lots of threads on this, some pics. |
Thanks for the link |
hmm. with SSI's cutting down to just one exit pipe shoudl help a little, but I bet it'll be loud still.
AutoBahned
I don't know if the internal arrangement of the Monty is like that of the factory cow horn style mufflers. If it is, you can block off the pass. side outlet with no loss of power.
thanks for the replies.
Assuming I want to keep the SSIs - which I do - what would be a good muffler to replace the monty with to get more refined sound levels. It would have to be a 2-in muffler. Any muffler recommendations for this? RG5. |
EARsoft™ Neon Uncorded Ear Plugs NRR 33dB - Large (200 pair per box)
EARsoft™ Neon Uncorded Ear Plugs NRR 33dB provide low pressure comfort with excellent attenuation Item #: A404-3125 Manufacturer: EAR Manufacturer Item #: CAS 312-1251 Product Type: Ear Plugs
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Bird. It's the word...
Is it interior noise, or external noise that concerns you most?
John Forcier Current: 68L 2.0 Hotrod - build underway |
AutoBahned
Otherwise the stock muffler is fairly quiet & does not lose power like many after market - but not all - do. |
exterior noise is what I want to get rid of, particularly at idle
abides.
You could try replacing the sound pads in the engine compartment and under the rear speaker deck. They tend to deteriorate and become ineffective, and there are superior materials available these days as well.
Graham 1984 Carrera Targa |
Choice !: Block off the Monty
Choice 2: 1 out gen 5 M&K. Big db difference between gen 1 and Gen 5.
Scott '86 911 Carrera Coupe, PCA, PBC |
AutoBahned
- even if not really satisfied, the action & "consultation" on your part may make her relent - next do the sound pad on engine side - last tear the whole cabin-side rear panel apart - and MAKE IT OBVIOUS that this is a big, involved job - soo big that it takes your time away from participating in whatever couples thing she wants you to do but you don't really want to do yourself - soooo big that the interior panel has to get stored inside her house for a while -- very sad - BUT an inevitable consequence or your satisfying her. |
Member 911 Anonymous
How about an E-Cut Off Valve. Once you leave your community, turn the sucker on.
![]() Or Diamond encrusted Ear Muffs?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
