Old 60's Porsche Tech
captainlewis's Avatar
Question replacing electrical portion of ingnition switch carrera??
Can you replace the electrical portion of the ignition switch without having to remove the steering lock key switch etc,// Thank s JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 04-20-2009, 02:51 PM
Almost Banned Once
sc_rufctr's Avatar
Yes you can but it's not the easiest way to do it... You have to be able to get to the small screws which holds everything together. But why not take the whole thing out?
Our host sells the shear bolts and at $5.75 each (x2) + $62.75 for the switch.
When I did mine I didn't use the OEM shear bolts. Instead I used 12 point bolts left over from another project.
I figured if the crook has a 12 point socket with him he would also have a punch and small hammer in his tool bag.
- Peter
Old 04-20-2009, 03:45 PM
I did it recently from under the dash, on an '82--same ignition switch, as far as I know--and with a little ingenuity and maybe some modifying of a small screwdriver it's easier and cheaper than taking the whole unit out, as long as you're agile enough to corkscrew yourself into the footwell head-first.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-20-2009, 03:52 PM
dshepp806's Avatar
corkscrew is right!!!!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-20-2009, 04:14 PM
Must go faster...
1978911sc's Avatar
My back still hurts from that particular corkscrew!!
Old 04-20-2009, 04:36 PM
Almost Banned Once
sc_rufctr's Avatar
E Mail from "captainlewis" replied to...
- Peter
Old 04-20-2009, 09:39 PM
