Replacing busings in Shift Coupler
Hello all,
I am attempting to replace the bushings in my shift coupler, how do I remove the center pin? I think I can punch it out, but I don't want to risk damaging the coupler or the pin. I can't see any snap rings, thanks for the replies. Here is a picture of my shift coupler.
82 911 SC 3.0, 915 |
Use a press. No pins are holding it in.
- Andrew 81SC |
Flat Six
Or improvise one with your bench vise, using a small deep well socket that's a smaller diameter than the pin.
Works like a charm.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
That's the ticket, thanks for the tip about the deep well socket.
Obsessed
There's nothing wrong w/ that coupler bushing
![]() The 915 is the worst shifting transmission ever It will come out eventually, the socket, heat, PB Blaster....just keep at it.
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
I used this and it worked like a charm - using a small socket as suggested:
1 Ton Arbor Press get the 20% off coupon from most auto magazines and it's pretty cheap. Karl |
French Import
+1. I used that method and it worked great for me.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Read the posting I put up a few hours before yours...jwakil
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
I posted about a new trick I found a couple of months ago. I have done a bunch of these on a press, but for ****s and giggles, I recently tried pushing out the pin with an air hammer, and a blunt punch. It works like a charm, and is way easier, and faster than using a press. Just put the steel part of the coupler in a vise, and tighten it pretty good, then drive the pin out with the air hammer using a blunt nosed punch. Comes out like butter, and goes back in just as easy. I probably have done 4-5 of these since I first tried it, and it works sweet.
No left turn un stoned |
Kantry Member
You probably have the pin out buy now, but the fastest method is to catch the square section in your vice and use a small drift to tap the pin out. (Fastfred is using a little more technology, but the same method.)
Assembly is the reverse. Takes a few seconds each way. Les
Best Les My train of thought has been replaced by a bumper car. Last edited by oldE; 12-20-2010 at 12:08 PM.. Reason: Noting information in another post |
