What's the deal? "CA smog failed twice" HELP!
Hello, Pelicanites. Calling all smog experts. I have a 1983 guards red cab SC. I'm trying to get my car pass smog here in sunny california. It passed last smog 2007 88k miles and also tuned up. Now at 90k miles and it failed twice already. The 15 mph HC (PPM) measure was too high at 254. The last was 52. What can I do to fix this? I have checked oxygen sensor and for vaccuum leaks. I appreciate the input. Thanks in advance.
Old 04-25-2009, 10:23 AM
Steve W's Avatar
high HC is either too rich, or unburt fuel - that's the black soot component of your exhaust.
Old 04-25-2009, 12:56 PM
thanks, steve. do you think if i adjust idle screw it would help with fuel mixture?
Old 04-25-2009, 01:04 PM
Steve W's Avatar
it might, but it also might not. theoretically your O2 sensor is modulating your mixture at stoichiometric, so your mixture shouldn't be either too rich or too lean. But you should check and adjust idle CO properly anyways. I'm rusty on the proper terminology for CIS, but the idle screw should be adjusted so the lambda valve is operating at a 50% duty cycle using a dwell meter.
Other possible causes, spark misfire could also be causing unburnt fuel in your exhaust. Also dirty or stuck injectors could be injecting excess fuel in a particular cylinder(s).
Old 04-25-2009, 01:14 PM
avendlerdp's Avatar
How did you check your O2 sensor? It' sounds like yours has gone bad.
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 04-25-2009, 01:30 PM
thanks, avendlerdp and steve again.
i didn't check the O2 sensor. but i'll do that. how do i know when my 02 sensor is bad?
RE: dwell meter. i don't have dwell meter. i would have to take to a shop to do it for me.
Old 04-25-2009, 01:37 PM
ruf-porsche's Avatar
If you haven't replace the 02 sensor after 90,000 miles, it's time to do so.
Old 04-25-2009, 01:46 PM
ok, thanks guys for the input. hopefully the sensor will do it. thanks.
Old 04-25-2009, 01:55 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
You don't pass smog......twice!
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-25-2009, 02:35 PM
hi, guys. found out that my sensor has broken ceramic connector from top. i don't what it's called. not sure if our host got them. i tried to do a parts diagram. it's not letting me. do you guys know what part that is or part number. thanks.
Old 05-11-2009, 11:39 AM
