LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
I saw your post from 2009 asking if anyone knew the dimension of the arm to measure the lash in a 901 gearbox. Did you ever get a reply? I am in need of that length now and haven't found a source as of yet.
914 racer
Old 02-13-2013, 02:20 PM
tools available
tools 11, 12, and 13 are available under different numbers along with the sleeve.
1983 Volvo w/Ford Mustang 5.0 and AOD
1990 BMW Z1 - sold
1973 914 2.4 slant nose
1987 959 - sold
1988 959 - sold
Old 04-21-2013, 12:33 PM
P259
I have P259 for sale but only as part of the VW385 R&P setup I will be listing.
1990 BMW Z1 - sold
1987 959 - sold
1988 959 - sold
Old 04-21-2013, 12:35 PM
Walt Fricke's Avatar
Low buck tool
My understanding is that the radial distance involved is to the outside of the ring gear.
This looks sort of like how the 930 did it.
The pinion shaft splined end is eversomuch harder than the old vice grip.
Old 04-21-2013, 10:16 PM
Walt,
The pinion shaft must be assembled & torqued for accurate backlash readings. When measuring pinion depth, you'll see substantial movement rearward when the pinion nut is undone. Likewise, the housing sidecover must be completely fastened down.
Jon B.
Vista, CA
Old 04-21-2013, 10:54 PM
T77911S's Avatar
Update:
"We haven't rebuilt one of those in more than 10 years" (it's probably being used as a door stop in the toilet)
did you ask where the toilet was
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-22-2013, 03:20 AM
Peter Zimmermann's Avatar
Originally Posted by werkstatt View Post
walt,
the pinion shaft must be assembled & torqued for accurate backlash readings. When measuring pinion depth, you'll see substantial movement rearward when the pinion nut is undone. Likewise, the housing side cover must be completely fastened down.
+1.
Keep the Shiny Side UP!
Pete Z.
Old 04-22-2013, 06:26 AM
Bringing this measurement into the G50 & G50/50 world... The tool to use is definitely the VW 521/4 with sleeve #9145. Measurement "a" is done, on a G50, from the flat side of the 521 to the tip of the adjustable insert in holder extension VW 388 (inscribed with "Made in Germany", no number, in below picture). The red insert is used to set the distance of 80mm.
For a G50/50 (Turbo), the white insert, tool #9196, is needed, and distance "a" must be 92mm. Of course, the measuring shaft of the dial indicator must be at 90 degrees to either the white or red gauge extension when measuring backlash.
Pete Z.
Old 04-23-2013, 11:46 AM
Almost Banned Once
sc_rufctr's Avatar
Thanks Pete
- Peter
Old 05-03-2013, 07:41 PM
b930's Avatar
Originally Posted by Jon B View Post
Grady,
The 101mm dimension is for early 930 transmissions, from the "Turbo Carrera" manual, page 39-17. Yes, that would be added to 15.95 for your "b" dimension in green. The ball on the extension tip is 10mm, so subtract 5mm for the actual measuring distance.
The original 915 manual shows the 901 backlash tool P259 being used, but I question how accurate that can be. The 915 ring gear is larger than a 901 ring gear. The P259 bracket was designed for use on Nadella flanges, and doesn't register on any CV flange. If using the 901 bracket on a 915, it should at least be modified for a different indicating point. The manual recommends doing this to the 905 tool for a 925, but doesn't to the 901 tool.
Hi, dragging up an old post. I have just rebuilt by 930/36 in my 88 930. I'm fitting a wavetrack. The pinion shaft is using the same factory spacer in front of the bearing plate so pinion is in the right place. Pinion shaft bearing is good, no play.
Before pulling bearings and spacers off the old diff, I'm trying to baseline the lash, the ring gear says it should be 0.16mm. It ran beautifully quiet with no problem.
Now in the 930 workshop manual, as stated above, they show tool 521/4, with gauge holder 388. If I work out where that would put the measurement in radius its about 112mm, very close to the OD of the ring gear. If I measure my factory set up here I get .25mm lash (Diff drive flange locked off and pinion shaft locked at the reverse gear). Way too high.
However, based on the comment above that the set up in the workshop manual is only for earlier turbo's, I did a bit of experimentation to see at what radius I get the required .16mm lash. That radius turns out to be precisely 76mm, very close to what the tool 215 (915 trans) radius. I am wondering if anyone can confirm the radius to measure a late model 930/36 lash if what is in stated in the workshop manual is incorrect. Thanks.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 08-28-2017, 02:08 AM
Geary's Avatar
I can't provide the answer for you (I'm sure someone will soon), but a couple comments to add to this great thread:
While "new" spec is 0.16mm, this dimension will grow over time as your R&P set wears. Resetting and older R&P set to 0.16 might not yield the quietest operation. Adding a tiny chamfer to edges of ring gear and pinion teeth with a dremel might be wise if insisting on setting an older R&P set back to 0.16.
Avoid shops that say they set backlash "by feel". My own experience is that while diff bearing preload can probably be set by feel, it can't be relied upon to yield an accurate backlash.
Old 08-28-2017, 05:56 AM
Almost Banned Once
sc_rufctr's Avatar
WOW... 8 Years just like that!
- Peter
Old 08-28-2017, 06:55 AM
b930's Avatar
Thanks so much for your response. I think I will aim at maintaining the current backlash so all I need is a fixed reference point in terms of radius of measurement and set the new LSD equipped ring gear back to that.
Old 08-28-2017, 04:46 PM
b930's Avatar
This forum is fantastic!
Old 08-28-2017, 04:47 PM
gearhead
This is where printing it becomes essential, before and after. See how it runs now and make sure it runs the same after. If the pattern is terrible now, you can't use the current settings as your after goal because it has moved too much and needs to be reset.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-28-2017, 05:42 PM
Under the radar
Trackrash's Avatar
"Printing"? Is that what you call it when you use blueing to see the contact pattern?
I have not heard of allowing wear on the R&P to justify more backlash. Is that true?
Thanks for your feedback.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-28-2017, 06:22 PM
Geary's Avatar
0.25mm is a bit high to reset to. Since the range for a new R&P is actually 0.12-0.18mm, I'd shoot for the high side of that, and check the new pattern against what you have now.
Old 08-29-2017, 05:00 AM
evan9eleven's Avatar
Hi everyone,
Can one of you tell me if this method of "painting" the R&P is an absolute necessary step in setting up backlash on a diff, and what the "paint" is?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 10-23-2017, 01:13 PM
The "painting" material is Prussion blue.
Lorne M.
83 SC
Old 10-23-2017, 03:06 PM
Thanks for a great thread.
The sensor (p259b)that goes into the end of the dial gauge pointer.. is it merely a right angled pointer? So when in use, does it touch against the side ribs of the cover?
In this photo it appears to be in two parts, but in the porsche manual, the photo only shows a single part...
Also, what keeps the P259 centralised with the output flange? I have the 259 arm, but it is a 'sloppy' fit...At this point, I have simply wrapped the shaft of the bolt with masking tape to remove the clearance and my hope is that this is enough to centralise the p259 with the bolt when it is tightened against the diff (using the washer to lock)
Thanks, Mike.
Originally Posted by Grady Clay View Post
Here are all the tools necessary for measuring backlash.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 11-16-2024, 11:15 AM
Tags
915 , p259
