Chakka71's Avatar
Alarm bypass
Followed the recommendations from the Forum since my alarm has had issues. Took me a total of 1 1/2hr to do and worked perfectly. Simple and straightforward.
THANKS!!
PCA National Instructor
93 RS America (some things done to it....)(gone)
85 Carrera (gone)
06 BMW M5 (gone)
"If you ain't first, your last"
Old 04-27-2009, 11:38 AM
Slumlord
Porsche_monkey's Avatar
Which thread did you follow? I have temporarily fixed mine by jumpering the 'unlock' input , but I need a long term fix.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-27-2009, 12:15 PM
Chakka71's Avatar
Just a few dollars in parts, heat shrink, insulated terminals and good wire. Just make sure your connections are tight. I had a wire come off when I put the ventilation system back in. I had to take it all out again.
Below is the link to the thread.
"No Cut" method for bypassing factory alarm
Its really pretty cool, the #15 circuit supplies ignition power to the 87a circuit. If you wanted to create a manual toggle switch it would go here. This would give you a great starter kill. Just route the wires under the dash to a hidden switch. The #61 terminals have to do with the alternator circuit. Connecting these two will keep your battery light off.
85 Carrera (gone)
06 BMW M5 (gone)
Old 04-27-2009, 02:05 PM
T77911S's Avatar
here is a link to a thread on how i solder wires, hope it helps.
What is the Solenoid?
this is for P monkey
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-28-2009, 05:08 AM
