LinkBack | Thread Tools | Rate Thread |
How to plug hole for thermoswitch on carrera style external/front oil cooler?
Hi everybody,
Long time lurker here... it's actually the first time I can't find an answer to one of my questions using the search button. I have a '79SC and I'm in the process of updating to a carrera late-style external/front oil cooler. I was wondering if something (any kind of bolt - if so, which thread size) could be used to plug the hole for the thermoswitch on the oil cooler itself. I don't plan on running a fan for now, so I'd rather not spend $40 on a thermoswitch that will be there just to plug a hole in the cooler. Any ideas are welcome. Otherwise I'll just buy the thermoswitch and call it a day. Regards, Serge in Montreal.
If you have an old thermostat switch just leave it there and don't wire it up for the electrical connection... If you don't have the thermostat switch then go your Porsche dealer, ask to see a plug and it probably has the thread size on the box then go to a specialty hardware store and buy a plug on the same dimensions and plug up the hole. (If you can't find a plug, see if any dealers in your area have a non-functioning thermostat laying around and use it to plug the hole.
___________________________________________ 2001 Boxster S, Orient Red Current Vehicle, 1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**, 1971 911T **Sold**, 1968 912 **Sold** |
i don't have a cooler here to check the hole size, but i think it's the same size as the plug or sender that is used on the right chain housing cover. 14 X 1.50. with a aluminum or copper 14mm sealing ring.
plugs
Serge, take a look at our website we make alot of block off plugs for engine/trans. 14x1.5, 12x1.0, 12x1.5, 18x1.5 (reverse switch), 18x1.5, also -6 fittings to do the cam feed fittings
if it is the same as the chain box sensor plug we have them. Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. Last edited by MBruns; 04-29-2009 at 08:11 AM.. |
Thank you ljowdy, John and Mike.
I now have options: some sort of M14*1.5 bolt, JB Racing plug or splurge and buy the actual thermoswitch. Will report back. |
Max Sluiter
Nice car! I like the speed shot.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I ended up sourcing a thermoswitch locally. Thanks again!
