Brorag
amp/volt gauge--rectangular shaped?
anyone know of an amp or volt gauge that would fit here?
sudo apt-get purge 930
You "might" find some custom digital unit but I doubt it.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
R&D guy
Location: the border between the states of inebriation & confusion
"Back in the day" I recall seeing (and actually using) small 'edgewise' panel-mount meters.
Some of you youngsters probably aren't familiar with the wide variety of analog meter that were once used. Not at all a bad idea to mount something like that in this spot, but the mounting depth might be an issue. I'm searching; so far the 185-series Yokogawa looks promising.
R&D guy
Update:
Yokogawa 280 series is available in sizes as small as 1 1/2" size. The actual bezel size of the smallest vertical meter shown below is 0.77" wide, 2.075" high, and the unit requires well over 2 inches of mounting depth.
