Low beams quit working and fuses are good.
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
These cars have no relays, power is feed directly via head light switch. Most likely the switch could be bad, very common failure. Or the hi-bean switch may also be failed.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Austin,
Ain't no relay. It all goes thru the contacts on the hi-lo/turn signal switch. You may be able to dis-assemble the switch and bend the contacts back into position. Many folks have added the headlight relay kit to handle the amperage from high power headlights. The Germans are smart for some things, not here.
Doug Was 2.7racer. '76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car. '85 3.2 stock, Orient red, comfy street car. |
You need to replace your headlight dimmer switch at the steering column. To avoid doing this every few years install a relay kit at your fuse box. Do a search here. I got mine from Marc Sucro, I think Daniel Stern has them I'm not sure if our host carries them. This will fix your problem.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Also,
Does the headlight switch turn the interior lights on and off? Mine just dims the dash lights. If so there is another problem with the switch. Thanks everyone Austin
I've only owned a 75 Targa and a 84 Cab, in these cars it does not turn on the interior lights.
Also, in my 75 car the hi-beem stick switch failed and I almost had a fire inside the steering col! Smoke was poring out and luckily the switch self destroyed before hand, and the fuse did not blow!
Sal, I will pull my wheel and have a look/test the high/low stick.
Pulled the light switch and found one wire not connected. The problem is there are no unconnected wires???
![]() Cleaned all connections but still no low beams.
The problem is in the stalk switch on your steering column not in the headlight switch. Just slap a new one in and add a headlight relay to avoid a repeat of the problem down the road, I went through one every 6 years until I did the relay
You might also want to check your fuses as the high and low beams are on different fuses. Make sure you only use ceramic not plastic fuses.
Thread Tools | |
Rate This Thread | |
