Crap!
Your motor is junk. Might part it out for what is left that is any good and that migh not be much. Looks like a rod did let loose. I have thrown a rod three times but never that bad. Once on a 930 and twice on a 72 911S so I can understand how you may feel. Get a used SC or Carrera and bolt thouse carbs up to it. |
That sucks! My condolences mate!
From the Blues Brothers
[A loud clunk is heard in Jake and Elwood's car.] Elwood: Oh no! Jake: What the f*** was that? Elwood: The motor. Thrown a rod. Jake: Is that serious? Elwood: Yep.
1988 Carrera Coupe |
Now in 993 land ...
Nut looks to be from the valve train. There are no nuts on the bottom end, AFAIK. Sorry to see the carnage.
Note that this will not qualify as a core engine if you go to a dismantler. If you are not willing to build something from scratch (or with what's left) I would disassemble and sell the good parts, then buy a good used engine to replace it. You can certainly disassemble this ok and have some fun doing it. Best, George |
Does that look too small to be from a rod-cap? If that's what it is, it's presence at the bottom of the engine (as well as the conditions at time of failure) probably indicate the mode of failure. Improperly assembled. You would think those guys could build an engine by now just by way of handling so many of them.
1989 Carrera 3.2L in 993 bodywork |
sucks bro. lots of good rebuilders here. supertec comes to mind.
poof! gone |
Case, one of more heads, crank, oil pump.
There is not much left. Another Motormister success story? |
Thanks for all the sympathies.
Should I go for a used engine or a rebuilt one? I no longer trust the rebuilt ones. I rather have a stock engine with documented compression test. Anything else I should check for when I am looking for a used engine? What do they usually come with? Approximate cost? Will my solex carbs work with any 3.0 L engine?
Zorin '79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP '00 BMW 540i - Sports Package (The Beast) '99 LandRover Disco |
Sorry to see that. Certainly looked like a rod failure from the beginning. It will be interesting if you can work out the failure sequence as you disassemble the engine and give us some idea of how MM condemned this engine from the beginning.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Carbon Emitter
Sad to see my prediction came true.
How many miles were on this MM "rebuild"? You should take a video of the carnage and post it up on YouTube to counter MMs running customer engine videos.In your case I would try to find a good used 3.0 "longblock", which is an assembled engine with heads, then swap the manifolds, carbs, and accessories onto it. Your Solex carbs are commonly called Zeniths if you want to search for info about them. They came on the 1970-71 911T with the 2.2 liter engine. Your carbs will work fine with your 3.0 provided they are jetted properly, which considering they likely came from MM also shouldn't be taken for granted. New jets are inexpensive and easily installed. You seem to have a good attitude about this...at least YOU weren't the one who paid $15,000 for this engine "rebuild" only to have to pay again! And compared to most of the homeowners in California, the money you just lost is chump change.
GAFB
This one's a rod nut. Can see the rod that let go in one of the pics. May I gloat at the "road debris, call your ins. co." guys yet? I think I can ![]() Zorin, sorry to see this, mate. I think your attitude has been admirable. We'd love to see detailed pics, every step of the way, of the disassembly.
Several BMWs |
Platinum Member
Nothing wrong with a rebuilt from a credible source.
You need to make sure the oil lines, tank, thermostat, cooler... whole oiling system is spotless clean, no metal parts left from this damage in the oiling system, or your new engine will be trashed. |
Free minder
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Now in 993 land ...
George |
Geezz, where'd this nut come from? LOLOLOLOLOLOLOLOLOLOLO FLMAORONFL!!!!!!
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
I just want to say this is freakin bad luck.
Sorry to hear it. Chris |
"Where did that nut come from?"
----------- My guess is a valve adjust jam nut. Vibrates off, flows through oil return tube to sump/screen. Is it possible that started the whole chain of trouble?
1987 Carrera 3.2 |
UnRegistered User
Sucks man....
Rip it down and see what is left... Post a motor wanted ad in both the for sale and the Canadian regional forum. To view it in a positive light, at least you have that MM monkey off your back! Good luck with your search.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Hmmmmm, lets not even imagine MM using the wrong nut on a rod bolt.....
My stomach turn to see it. best of luck to you. Shawn
2005 911 carrera 57 BMW r50, 2007 Ducati s2r 1000 2007 Boxster (sold) 77 2.7 911s chocolate w/ducktail (Mr Hankey) (sold) 77 930 black (sold) |
Band.
Sorry about your misfortune.
![]() It is true, that disassembling that engine would be a great learning experience and we could look at your amazing pics.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
