Packy's Avatar
Question Removing Trim/quarter window
Can anyone tell me or show me pictures of how to remove the quarter window and reinstall it? I can't find anything on the forum.
The Haynes manual tells you how to remove it, by cutting the rubber seal and taking out the window, but you can't exactly do the same process in reverse. I don't want to break the glass when I reinstall the window.
Thanks,
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 05-06-2009, 09:24 PM
Diamond911's Avatar
Hi Packy,
This thread should help:
BLEEEEPing rear quarter windows!
cheers,
1988 911 3.2 Carrera (Commemorative Edn), 1988 928 S4
Old 05-06-2009, 09:31 PM
Packy's Avatar
perfect. Thanks Diamond.
BTW, how did you do that so fast? I guess my search skills need work.
Toluca Lake, CA
Old 05-06-2009, 10:01 PM
Diamond911's Avatar
The search function is pretty easy once you get the hang of it and a fantastic resource.
I just ran an advanced search on the 911 forum only (ie click on search then advanced) using the keywords "quarter + window" in the thread title only.
Glad to help.
Old 05-07-2009, 12:50 AM
Porsche Head's Avatar
If you are removing the glass and replacing the glass to trim seal when you put it the trim back together with the angle braces use a large clamp to hold everything together. This way you won't breakt the angle brace when trying to screw in the mini screws to hold it all together.
The final seal on the outer part of the trim needs soap and water and press real hard right on the center of the seal to drive it into the groove. Run your thunb (or other hard object) along with soapy water back and forth.
1972 911E w/3.0 RS Replica
1988 M5 300hp
2016 Audi Q5 TDI
Old 05-07-2009, 10:10 PM
Tags
quarter window , seals , trim
