Please don't flame me...
I did something very stupid due to impatience. after a top end rebuild and refreshment of my 68 912 engine I reinstalled it today and when I started it, it was wildly backfiring
so I shut it off after running it for around ten seconds and just pondered. this wasn't your average hickup backfiring, it was consistant. finally after a couple hours I realized it was because I was missing a valve adjustment nut. --enter brute critisism here-- so my question is, do I just shrug it off and stick the valve adj. nut on, or do I drop the motor again to check for damages?? what is the worst that could've happened? anyway.. I know I'm Dumb. no need to tell me.
I think I'd pull the plugs and do a valve adjustment paying close attention to how hard it is to turn the motor over by hand.
Once the valves are adjusted and you're sure there's no bent valve I'd crank it, without the plugs in, using the starter. If all sounded good I'd then put the plugs in and give it a shot. 912's are tough little engines, I don't think 10 seconds is going to kill it. (I had a '67 912 Sunroof coupe before getting my SC)
Scott '78 SC mit Sportomatic - Sold |
And maybe before that, one fine glass of bourbon/wine/beer/your choice and go a little easy on yourself. We're all human.
Congrats on the rebuild.
Glenn 87' 930TT |
Dumb things
I have done many more dumb things than I will ever admit.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
I'll surely do that before I fire it up again. No alcohol for me though...underage. By the way scott, I'm located in OC as well! Thanks for the advice!
Don't think that nut would cause it to backfire, Double check that your plug wires are on correctly.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I go with Pete 100%. |
I'll be sure to double check that too! Thanks milt&pete!
I'm a little slow: Did you forget the nut, or did it back off and end up in the motor somewhere?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I accidently left it out because I was going to replace it, the threads were bad. My mental note wasn't good enough to remind me though. The whole reason I had to do a rebuild was because the previous owner dropped a tin screw in the cylinder so frankly I'm sick of things being stuck in my engine. it was simply forgotten.
If the adjuster went loose then no worries. so long as the rocker and cam are not damaged from the extra lash there is pretty much no way anything south of the valve got damaged. I wouldn't think that an adjustment screw would go tighter in that situation.
1989 Carrera 3.2L in 993 bodywork |
I'm with Bill
I doubt very seriously you have any engine damage. With the nut missing, the valve simply not open far enough to hit anything. I would be more concerned with the foot of the rocker damaging the cam lobe by "smacking" against it. You sure didn't run it long enough to do that. If the nut in question was left off the exhaust valve it will surly backfire since the cylinder would not be able to fully empty itself during the exhaust stroke. I would install the nut, check all your valve clearances, check your firing order and hit the switch.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
When I missed my shift a couple of years ago, the impact of the exhaust valves spun three of the adjuster nuts off, a common occurence. One of them looked like a pretzel, but surprisingly did no damage in it's travels around the drive train. I did replace the adjuster screws as those 3 did get a slight bend.
Wer bremst verliert
As mentioned above, consistent, repeatable misfiring is often the result of switched plug leads.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
too young to drink. huh, he's got a lot of years left to do more stupid stuff that most of us have already done
![]() we have all done stupid things, whats bad is when you do it twice.
