LinkBack | Thread Tools | Rate Thread |
Hey guys,
I'm re-installing my spring plates after upgrading my rear components (new torsion bars, poly-bronze bushings, Tarret rear sways and monoballs). I plan to bring the car in for a 4 wheel alignment & corner balance when I'm done. I centered the height adjustment eccentric bolt and locked it in place. Wondering if there is any particular setting (center?) that I should shoot for with the toe and camber eccentric bolts to make it a little easier on the shop that will be doing my corner balance & alignment. Should I just install them in any position and let the shop figure it out? Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 05-10-2009 at 08:34 PM.. |
I can look this up if it's not making sense, wish I had better recall. I think the shop manual alludes to this, but it wasn't clear to me until I did it myself.
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) Last edited by Jim Williams; 05-12-2009 at 05:07 AM.. Reason: corrected grammar |
Alignment
Jim,
Thanks for pulling this up, appreciate the gouge. I've installed the camber and toe eccentrics in semi-random positions (tried to at least match side to side for what that's worth. The shop/person I will be bringing it to is very familiar with 911 alignments - pretty busy so I didn't want to call with a question I knew someone would have the answer for here. Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
