Does new alternator VR need break-in?
Installed a brand new Valeo voltage regulator (from our host) to the alternator and now the charging light stays on with very slight blinking at idle and only goes out at 2000+ rpm.
Since the brushes of the new VR only contact the rotor copper wire at a smaller area than the crescent perimeter of a used one, could that new VR brushes need some time to break in before the charging light would go out at idle? Thanks a lot!
'87 3.2 Targa
Old 05-12-2009, 06:55 PM
mca mca is offline
mca's Avatar
Check fan belt ... Might be loose
Old 05-12-2009, 07:03 PM
Pretty tight!
'87 3.2 Targa
Old 05-12-2009, 07:09 PM
Friend of Warren
Originally Posted by alniki View Post
Pretty tight!
It does not need to be "broken in." Oh and you should have at least 1/2" deflection in the middle of the belt. Too tight is not good at all. Leads to premature bearing wear.
Kurt V
Old 05-12-2009, 07:12 PM
Kurt, I don't like it to be too tight, either.
Am thinking about the possibility of slipping at the pulley area as I used some silicon spray to finish the alternator fan/case after cleaning them. Though I did slightly clean the central part of the fan there may still be some left.
'87 3.2 Targa
Old 05-12-2009, 07:24 PM
