briancoates's Avatar
Ignition Question
Hi All, I finally got the new 3.0lt engine. Install went without a hitch except I now have no spark. The car runs an after market ignition system that when working performs faultlessly. The new engine has an electronic distributor, green pulse wire with braiding. The old points distributor had a single pulse wire that triggered the ignition.
Question is: what does the green wire and braiding do and what connections need to be made to trigger the ignition.
All help appreciated, cheers
Old 05-13-2009, 03:03 AM
Hendog's Avatar
I don't know, but a few guys here converted their Pcars to aftermarket ignition.
Free bump for ya.
Henri
'87 Carrera coupe: Venetian blue
Old 05-13-2009, 08:05 PM
Thanks for the bump...... I found out today that that CDI modules designed to run with points are totally different than those for electronic distributors and are not interchangable. Looks like I will have to fork out for a new ignition system.
Such is life.
Thanks anyway.
Old 05-13-2009, 11:11 PM
Sigurd's Avatar
I think you should get it to work.
The green wire carries the pulse from the distributor to the CDI box to trigger a spark.
Can you explain how your aftermarket ignition system works? I see you have a 3 connector CDI plug; how is that on a 3.0 engine? Didn't they use a 6 connector CDI?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 05-14-2009, 02:49 AM
The car was originally fitted with a 2.7 and 3 pin CDI thus the wiring, the previous owner fitted a 3.0 engine and run a modified 2.7 distributor wich used points and the original 2.7 engine harness. A bit of a mess really, anyway I have fitted a new 3.0 engine with the correct wiring and dizzy. The aftermarket CDI is designed to run with points and the electronic dizzy does not have the direct grounding needed to fire it.
This is what I will be fitting at this stage
Old 05-14-2009, 03:28 AM
T77911S's Avatar
just a thought. what about using the 6 pin CD? or better yet, go to the MSD box. its cheaper
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-14-2009, 03:38 AM
When I purchased the new engine I paid for an original 6 pin CDI and coil although they cannot be supplied. There is apparently no second hand units available in Australia. The M&W unit is less than $500 Aus and the recommended MSD unit is about $1100 Aus. The MSD unit has adjustable ignition cutouts and retard settings for starting etc although those options are not needed. The M&W is much simpler.
Decisions decisions..........................
Old 05-14-2009, 04:00 AM
T77911S's Avatar
money money................
RACE CAR:: sold
Old 05-14-2009, 08:29 AM
