Where does this oil pipe go??
Hi, in the middle of CIS inspection etc, i have found this oil pipe not going anywhere. Ive searched through the forum and all i could see were reports of a drop in rpm at idle when opening the oil cap. I dont get this.
Does anyone know where this should be connnected and should i see an rpm drop when i open the oil cap with the engine running? Thanks
Old 05-15-2009, 05:35 AM
Peter Zimmermann's Avatar
The parts shown are not P-car parts - they're after market stuff for one reason or another. Show us a pic of the entire engine compartment...
Keep the Shiny Side UP!
Pete Z.
Old 05-15-2009, 06:27 AM
Please find pics attached. its aint pretty.........
Old 05-17-2009, 11:27 PM
that's an early cis engine with a late carrera oil tank. it's a carrera vacuum valve that doesn't relate to your engine. it's just plugging a tank outlet now.
206 637 4071
Old 05-18-2009, 05:07 AM
Somatic Negative Optimist
Gunter's Avatar
Dave,
You can make improvements:
Change the 5-blade fan to an 11-blade type for better cooling.
Block the airduct on the left with thick vinyl and a clamp so you get more air going over the cylinders.
Remove the pedestal for the missing heater blower to the left of the throttle body.
Make sure the thick oil breather hoses from the oil filler stud are firmly connected on both ends: One goes to the breather cap on top of the engine, the other goes into the big rubber cap between the throttle body and metering unit.
Clamps on both ends will make sure there is no leak.
If the braided ignition wires are very old, they may spark over; you'll see it when it's dark.
Check the Beru connectors for correct resistance: 1k OHMS for the short type cap-end, 3k for the long plug connectors.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-18-2009, 10:03 AM
Thanks, so i can just leave it as is then? and should i see an rpm drop if i open the oil cap?
Old 05-18-2009, 12:27 PM
Thanks Gunter, im in the middle of installing a oil cooler upfrotnand will add the 11 blade fan. i just have the fan and hoses removed for checking CIS stuff. i will check all other hoses as recommended, cheers!
Old 05-18-2009, 12:30 PM
