axvel's Avatar
Send a message via ICQ to axvel
Clutch Pedal
HI, I have couple of questions, hopefully you guys can help.
I have a new clutch with a new pressure plate. I installed it and it was fine. Meaning soft pedal that was engaging too far, so i went to a porsche shop and asked them to adjust the cable. They did, so the pedal became super hard. I thought it was normal after all this is my first 911. And i thought it was normal.., couple of days ago i drove my friends 911 3.2/915 and his was 10 times easier to depress also with a new clutch. That upset me a bit. I went back to the shop who did the adjustment and asked them about it. They said that there is no way the cable adjustment could have caused that. They also said that my pressure plate is bad. Meaning that when pressure plates are old then they get hard.
1) So i guess my question is...can the clutch cable be adjusted or loosen up a bit?
2) Is there maybe a pedal itself that can be adjusted?
3) is there a way to check the clutch itself without pulling it apart?
thanks in advance
p.s. i searched
Old 05-21-2009, 12:30 PM
Fast Corners's Avatar
What year is your buddy's 3.2? The later model 3.2's have a hydraulic clutch and would require a lot less effort to dis-engage the clutch.
Just making sure you are comparing Apples to Apples.
Edit:
Sorry, I missed the part about the 915. There are a number of things to check regarding a stiff clutch. Pedal bushings, the helper spring, etc. The springs can be visually checked from under the car. Binding of the pedal bushings can be checked by disengaging the clevis and rotating the pedal with out any load on it.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Last edited by Fast Corners; 05-21-2009 at 12:41 PM.. Reason: Lack of reading skills
Old 05-21-2009, 12:34 PM
axvel's Avatar
his is the 1974 conversion with a 3.2 and a 915 tranny
mine is a 1975 conversion 3.2 with a 915 tranny
I know he doesn't have a hydraulic clutch
Old 05-21-2009, 12:36 PM
Band.
Do both of your 915s have "helper spring" assemblies?
If yours does not your clutch would understandably be harder to push.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 05-21-2009, 12:42 PM
axvel's Avatar
Helper spring is there on both of our cars, can the helper spring be tighter on mine maybe? or they are all the same?
Old 05-21-2009, 12:43 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Remove the cable and see what condition it's in. The cable assembly is somewhat of a wear item and it's good to replace when a clutch job is done. Also make sure the cable is routed properly- consult a Bentley manual. If the cable is routed wrong, it will damage the cable and produce stiffness like you describe.
Kevin L
'86 Carrera "Larry"
Old 05-21-2009, 01:31 PM
