krl krl is offline
Post 901 engine dimensions, specs wanted
Hi people.
I've got a bunch of questions about 901 engines: (not the new 911 engine, but the ones used '68 to mid/late 90s)
How big are they: width (valvecover to valvecover), length (flywheel to back ?), height (oil "pan" to top of fan) ?
How much do they weigh ? Do the large displacement engines weigh much more than the small ones ?
How big is the clutch/flywheel on a 901 engine ?
Does the cooling fan push air over the heads or pull it from underneath the car ?
How are they at staying cool in hot applications at moderate power ? What about when they are turbocharged ?
What direction does the engine turn ?
What is the biggest displacement 901 one can build ? 3.4L ?
How "thick" is the pancake, ie if it wasn't for the fan, intake and exhaust, how thick is the rest of the engine ?
How far does the "oil pan" (I know it uses a dry sump system) extend below the bellhousing circle ?
How many amps does the alternator put out ? (It is built into the fan, right ?)
Are they all SOHCs or is there a DOHC engine ?
Which engine parts are aluminum and which are steel ? Are the cases aluminum ? Are the cylinders ? Are the heads ?
If there is a FAQ somewhere answering these questions, let me know.
Thanks.
KRL
[This message has been edited by krl (edited 06-08-2001).]
Old 06-08-2001, 10:52 AM
