'79 SC Flooded the engine, now it wont start H E L P
My '79 was parked behind my girlfriends car and I went to start it but did not notice that I left the A/C on when I shut it off an hour earlier. It started, stalled and won't re-start. I smell gas in the engine compartment and I'm 100% sure I flooded it by pressing down on the accelerator while trying to start it. I've tried 3 other times tonight and nothing, it cranks, wont start and smells of gas, WHAT DO I DO?
Is there a procedure to de-flood the engine?
Old 06-16-2009, 03:53 AM
Your biggest concern with this no-start is the possiblity of hydro-lock in the cylinders. Cranking the starter activates the cold start injector, and the vacuum created by the cranking raises the lever in the plenum of the throttle body causing the injectors to eject fuel. Under these circumstances, without the engine firing, flooding the cylinders can occur. That being said, the degree of flooding is not dependent on pushing the gas pedal down but on the turning of the engine without ignition.
Unless you cranked incessantly, your flooding may not be too serious, but for peace of mind you can remove the spark plugs, remove the fuel pump relay, and crank the engine over a bit to insure the cylinders move freely. Once you get the engine to start, be sure to change the oil as it probably has been diluted by the gasoline.
Your post sounds like you may have an ignition problem or possibly the pop-off valve is stuck open. Did the car backfire before it stalled? Do you have a popoff valve? Have you checked to see if you have spark? Let us know whatever you have found up to now.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-16-2009, 08:01 AM
Senior Advisor
James Brown's Avatar
is this a CIS engine? hard to "flood" it could be a ton of other things wrong like ignition. go through the engine fails to start checklist and make sure everything is working properly and don't pump the throttle on an injected car when starting!
08 Cayenne Turbo
Old 06-16-2009, 08:58 AM
Designer King
Paulporsche's Avatar
To get you going, try removing the bellows above the sensor plate. Have your GF push the plate up while you turn the key.
You should always verify your ignition components are working correctly. Was yourAC actually running while the car was off? Sometimes the battery is run down enough so the starter will still crank but the ignition will not fire. Check for spark and/or battery output. You may need to charge it up.
Have you been having any other start problems? Maybe your mixture or fuel and control pressures are off, or your AAR is malfunctioning, or a vac leak
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-16-2009, 09:41 AM
the the is offline
just take the plugs out, dry them off, reinstall and you should be good to go.
Old 06-16-2009, 09:46 AM
No power at the coil
Cleaned plugs...still wont start. Checked for spark, nothing. Checked for pwer at the coil, nothing. It is an ignition problem, what do I check now, any ideas?????
Old 06-16-2009, 08:49 PM
Free minder
Aurel's Avatar
Do a search for "green wire".
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 06-16-2009, 08:57 PM
Senior Advisor
yeah thought so, what ignition system is on there? stock or other? check fpr power at the ign box also, my coil wire corroded through once, check the condition of all the wires, and pop the cap, look for broken things!!
08 Cayenne Turbo
Old 06-16-2009, 08:58 PM
Still not running
Here's where the story continues:
My 1979 911 SC with (68K Miles???)
Old 06-20-2009, 07:02 PM
ruf-porsche's Avatar
Do you hear a whinning sound from the CDI?
Old 06-20-2009, 09:49 PM
The CDI checked out okay, it turned out to be the pick up coil. That is a different problem with the distributer. See my other post.
Old 06-20-2009, 10:03 PM
