Black and Blue
battery light on at idle...goes out with higher revs
does this mean the alternator is starting to fail? i have a new optima red battery and just had a new voltage regulator installed.
thx
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Tighten your belt maybe? (fan belt, not the one on your pants).
Todd
'81 SC |
Northern Motorhead
Check your battery voltage with an ohmeter... it should read over 14 volts,even at idle !
zugelassener benutzer
that's how mine let me know it was done.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
I would suspect bad diodes in the alternator.
EMT/TechRescue Instructor
David 1986 Iris blue 911 Cabriolet 2017 Ram 1500 Night edition 2025 BMW X-5 |
Black and Blue
great...i just had the alternator out in the rebuild shop... the only thing replaced at that point was the voltage regulator. i guess the rebuilder missed the other. ill check with the voltmeter.
thanks for all the replies.
My '72 911E has been doing that for five years now. I haven't seen anything change...
Vic |
Depending on the year of the car, alternator brand/type... it could be normal. I recall my 356 doing that all the time - perfectly normal; however not to normal on a 911, based on what you've doen already, check the alternator.
Less brakes, more gas!
Mine has done that for over 10 years... At idle, I get 14+volts at the battery, but the light is bright. I remember reading something about changing the resistance on the bulb when moving to a different style of voltage regulator. This was in a Porsche Factory bulletin. I figured I'd just ignore it for now... that was 10 years ago
![]() -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
