Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
battery light on at idle...goes out with higher revs
does this mean the alternator is starting to fail? i have a new optima red battery and just had a new voltage regulator installed.
thx
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-27-2009, 05:26 PM
toddu's Avatar
Tighten your belt maybe? (fan belt, not the one on your pants).
Todd
'81 SC
Old 05-27-2009, 05:45 PM
Northern Motorhead
wildcat077's Avatar
Check your battery voltage with an ohmeter... it should read over 14 volts,even at idle !
Old 05-27-2009, 07:35 PM
zugelassener benutzer
teamfee3's Avatar
that's how mine let me know it was done.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 05-27-2009, 07:52 PM
I would suspect bad diodes in the alternator.
Old 05-28-2009, 06:15 AM
EMT/TechRescue Instructor
86911cab's Avatar
Originally Posted by 73rustbucket View Post
i would suspect bad diodes in the alternator.
+1
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 05-28-2009, 05:18 PM
Black and Blue
Kemo's Avatar
great...i just had the alternator out in the rebuild shop... the only thing replaced at that point was the voltage regulator. i guess the rebuilder missed the other. ill check with the voltmeter.
thanks for all the replies.
Kemo
Old 05-28-2009, 08:11 PM
My '72 911E has been doing that for five years now. I haven't seen anything change...
Vic
Old 05-29-2009, 04:46 AM
Depending on the year of the car, alternator brand/type... it could be normal. I recall my 356 doing that all the time - perfectly normal; however not to normal on a 911, based on what you've doen already, check the alternator.
Old 05-29-2009, 05:08 AM
Less brakes, more gas!
euro911sc's Avatar
Mine has done that for over 10 years... At idle, I get 14+volts at the battery, but the light is bright. I remember reading something about changing the resistance on the bulb when moving to a different style of voltage regulator. This was in a Porsche Factory bulletin. I figured I'd just ignore it for now... that was 10 years ago
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-29-2009, 07:50 AM
