efhughes3's Avatar
I love it when an anticipated problem job goes easy...
I found a broken CV joint bolt the other day. So, up on the lift she went yesterday.....I helped a buddy go thru the pain once of doing this on his, so I expected the worst. A broken easy-out didn't help then.
At any rate, I lucked out. Instead of having to remove the CV and fiddle with removal, I was able to stick a small flat screwdriver into the CV joint hole and actually drive the broken threads out the back side. Since I had the CV bolts in stock , it took all of 15 minutes including checking the others. This partially makes up for some of the "simple" jobs that went bad.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-31-2009, 12:56 PM
Northern Motorhead
wildcat077's Avatar
Just curious...
What brand of lift is that and how high is the ceiling in your garage ???
Can you tell me the overall dimensions of your setup as i've been thinking
of getting one ! I have a 10 ft ceiling ...
Thank you !
Phil
Old 05-31-2009, 01:25 PM
efhughes3's Avatar
My ceiling is 9'6", the lift is probably up 48" in the pic. It goes to about 54", which is higher than you could ever need to go, unless you're a leprechaun.
The lift is about 42" wide X 84" long, probably 66" wide to the outside of my ramps, which are 10' long.
Ed Hughes
2015 981 Cayman GTS
Old 05-31-2009, 01:46 PM
Almost Banned Once
sc_rufctr's Avatar
Well done on the simple fix but.... How did you check the other bolts?
(assuming you didn't remove them)... Please remove the other bolts and check them on your bench.
Make sure they're straight and the threads are good. If you find any that are not 100% remove all (24) and replace with brand new as necessary.
I hate to be negative but if one bolt broke what are the chances the others are fine?
FYI: I did a major service inspection on my car just after I bought it.
One of the things I checked were the CV bolts as I was aware of the problems these can have.
They looked fine installed but after removing a few to check I found that some of the bolts were kinked and bent.
As a result I serviced the CVs and replaced all 24 bolts...
- Peter
Old 05-31-2009, 02:32 PM
Northern Motorhead
wildcat077's Avatar
What company makes that lift and do they have a website,it looks pretty interesting !!!
Old 05-31-2009, 03:27 PM
efhughes3's Avatar
Please note that I did state I checked the others, no need to assume anything here. I kind of put 2 & 2 together .....this was adjacent to one that had backed out a while back, and is most likely the reason for the crack. The only other reason could be a bad batch as these were replaced about 4 years ago when the CV's were loosened for an engine drop. I'm a bit anal about checking these, particularly since the one had backed out.
I'm probably going to replace the 1/2 shafts in July, as I don't know when the CV's were last serviced, if ever.
I'm sorry, I forgot to answer that: BendPak.
Ed Hughes
2015 981 Cayman GTS
Old 05-31-2009, 04:24 PM
muck-raker
kidrock's Avatar
If I had a garage like that, I'd never make it to my day job. And, my wife would've left me a long time ago.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-31-2009, 07:42 PM
