Wer bremst verliert
Fitting size question
What fluid fitting (plug) has a 13mm diameter across the male threads, 11.2mm across the female threads and has a 1.25mm threadpitch?
Is that a 12mm, a 13mm or some other imperial size? This is for a plug on a swedish (opcon/autorotor) supercharger. Trying to order the right fittings to plumb in a pump and cooler with the transmission. thanks
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Wer bremst verliert
Any help out there please?
Did you notice if the threaded section is tapered or straight?
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Wer bremst verliert
Straight. Pulled out the Engineer's Black Book...1/4 BSP maybe? Earls has a part number to adapt to -8 but not at Summit...
Yes, 1/4" BSP. Major diameter is 13.15mm with 19 TPI. (Don't know about 1.25mm pitch.) Straight threads require a sealing ring though.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. Last edited by bazar01; 06-01-2009 at 06:33 AM.. |
