Need help with hose identity
Guys can anyone help identify where these hoses should hook up too? This first one comes from the firewall under the cruise control unit. It is broken off and I can not see a fitting where this could attach to on the left side of the engine. Now it might go over to the right side but I can't seem to find a missing hose connection there either.
This second one comes from the transmission tunnel area. It runs along side the emergency brake cable, the throttle cable and the heater cables. It too is broken off and I have no clue where it would run to.
Thanks in advance for any help you can provide. This is for an 83 911sc cabriolet.
Gary Kozun
83 911SC Cabriolet
Old 06-02-2009, 11:32 AM
Band.
1st one looks to me like part of your evap/carbon canister setup. Second one, I don't know.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-02-2009, 11:45 AM
gtc gtc is offline
abides.
gtc's Avatar
Edit: Nevermind... wrong size for the brake booster.
I admit, I just clicked this thread because of the title...
Graham
1984 Carrera Targa
Old 06-02-2009, 11:55 AM
Thanks Gogar. I think that you are correct. I believe that this hose goes on the left side of the air box as I found a nipple on there that the hose would fit and it was plugged off in a non factory manner. I hope that this is right. Will await further experts advise.
Now only need to figure out what that hose is in the second picture and where it hooks up to.
Gary Kozun
83 911SC Cabriolet
Old 06-02-2009, 05:06 PM
Never mind guys. Found where the lines go to. Thanks for the replies.
Gary Kozun
83 911SC Cabriolet
Old 06-03-2009, 10:37 PM
