bosch cdi pin out help
Hi guys
I am confused by the pin out of the later 6 pin Bosch CDI. There is a diagram on the side of the unit. Is that the diagram of the male pins on the unit or is that the diagram of the female connectors in the cable to the u nit.They would not be the same, they would be the inverse of each other. I did a search and found a cllassic post by Warren. Here it is. ]Here is the pinout looking into the connector with the mounting flange sitting on the hand or table ... . 31/1 ... TD ... 31d . A . . . . 15 . . . 7 ============== 31/1 -- Power ground 31d -- Signal ground [green coax shield] for trigger signal 15 -- +14 Volt power lead 7 -- Trigger signal from distributor magnetic pickup coil TD -- Tachometer Drive signal A -- +460 Volt pulse output to coil __________________ Warren Hall, Jr. If I am reading this correctly, this is the schematic of the female connector and not the pins on the cdi unit. Can anyone confirn this or post an image of the connector so I can see the wire colors entering the connector. Thanks |
The connections for 7 and 31/d are interchanged. The green wire should go to terminal #7. Send reply to atd911@hotmail.com and will forward the coded wire color for the 6-pin Bosch CDI. Tony |
The diagram on the box refers to the box male connector when you look at the connector. So the two GND connections are away from the flange.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Wer bremst verliert
I'm doing a fresh rewire on a car, so no remnant wires to trace or mimic...
Who was right here, Warren or Tom? FYI im installing a 6-pin Bosch CDI, crane optical distributor, bosch blue coil. Interested in confirmation of the coil wiring too if anyone is up for sharing. Thanks
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
When you look at the connector on the box that is what the sticker shows.
![]() Ingo
Fleabit peanut monkey
Perma Tune High Performance Ignition Systems
Permatune has a great pin out diagram. I have posted this about eight million times. Amazing none of the old-school boys use this as reference.
1981 911SC Targa |
Check and compare.........
Bob, Please compare the schematic diagrams for Bosch CDI (factory manual) and the Permatune CDI (your attachment). The wire color coding is totally different and could easily confused anyone. I'm still having a problem following Permatune's wiring diagram using the OEM wiring harness (colored wires). However, Ingo's illustration although did not include the wire color coded wires is easy to follow. Thanks. Tony |
The Permatune diagram shows every input to the box.
If the female connector is intact there is no reason to have to match color codes to the factory diagram. The pin out, like Igor's picture and in the Permatune diagram is THE PINOUT. I had no confusion.
1981 911SC Targa |
