3.2Carrera's Avatar
Getting ready for first autocross..
Well I am getting my car ready for its first autocross. I was just wondering if any of you guys had any suggestions for what needs to get done before i go out. I recently installed new shocks and struts(Bilstein HD'S), new tires, brakes and lines. Any tips or recommendations would be helpful. Thanks !!
-Joey B.-
1985 Carrera
http://www.pelicanparts.com/gallery/3.2carrera
Old 06-15-2009, 11:21 AM
(the shotguns)
berettafan's Avatar
Check tire pressures, check wheel bearings (wiggle tires at 12/6), empty car out, get ready for a good time!
Old 06-15-2009, 11:49 AM
abit off center
cgarr's Avatar
Walk the track and don't get lost! Nothing more funny than watching someone just drive randomly trying to find the exit, and yes I have done it! SMOOTH IS FAST
______________________
Craig
G2Performance
Old 06-15-2009, 11:55 AM
At the track = great day
ChkbookMechanic's Avatar
For you: sunscreen, a large hat and lots of water
For your car: alignment and what berettafan said
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
3.2Carrera's Avatar
Thanks guys, just installed new wheel bearings in the front forgot to mention ...
-Joey B.-
1985 Carrera
Old 06-15-2009, 11:57 AM
3.2Carrera's Avatar
whats the best way to worm the oil b4 my run??
-Joey B.-
1985 Carrera
peppy's Avatar
Oh so true. I was as lost as a fart in a whirlwind my first time. Slow can be fast too.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 06-15-2009, 12:09 PM
Techne's Avatar
I haven't AX'ed my 911 yet, but I hear you might want to pull the windshield wiper fuse - it is easy to bump the stalk and you end up racing around with the wipers going...I have seen it and it does look a little goofy.
1984 911 Carrera
Old 06-15-2009, 01:03 PM
Driver8's Avatar
They usually have 3 groups at an autocross, 1 group working, 1 group driving and 1 group resting. When you are resting, start the car and let it idle.
Just go and enjoy yourself. With this being your first autocross there is a lot to learn and you will certainly have information overload.
Don't be afraid to ask if they have instructors who can ride along with you. That's the best way not to get lost on course.
Old 06-15-2009, 01:05 PM
RETIRED
Joe Bob's Avatar
Nothing says Rookie Newb more than flapping windshield wipers coming out of the 180....
2012 ML350 3.0 Turbo Diesel
Old 06-15-2009, 01:09 PM
Watch out on letting the car idle, depending on the outside temperature (i.e. Texas or someplace in the south) you could be hopping into a car that is about to overheat.
Definitely get as many ride alongs as you can.
Lane
Old 06-15-2009, 01:37 PM
Transplanted User
mkossler's Avatar
Smile
Gee, and here I thought I was demonstrating Rookie Newb mojo just fine this weekend, when I was exiting the track surface backwards at 75-80 mph on turn 4 at Roebling. Yeesh. Then again, that was a DE and not AX-ing.
At least I got that first experience out of the way early.
3.2Carrera, good luck! Prepare for the fire hose of information...
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 06-15-2009, 02:18 PM
Send a message via Yahoo to algs911
Have a great time! I think EVERY new driver (not that your are) should do an AX. It's a great way to learn about your car, your abilities, etc.
Being a tech inspector and an instructor, I think I can offer the following in addition to the tips already mentioned.
Make sure the batt is tied down. I've seen cars fail tech inspection because of this. It's amazing how many cars have the batterey just sitting there, not tied down!
Bring a nice air gauge with you. You'll start your first run with, say, 36 psi. After your first run the air in the tires will heat up, thus increasing your tire pressure. Use the gauge to bring the pressure back down to a normal level. Once you get used to this you may want to experiment with tire pressures front to rear, left to right (so, bring an air pump too, even a nice bicycle floor pump will work). ASK other drivers (in similar cars) what air pressures they're running (ask a veteran AXer, they're usually great help).
Remove the dust caps from the wheels (not the dust caps on the hubs, just the hub-cap type caps that are there just for looks). Although I've only seen one fly off, it did get really scratched up (bummer).
Many people remove the spare wheel/tire, tool kit, etc. from the frunk (front trunk).
Floor mats can get in the way sometimes. May want to remove them.
Wear full finger gloves. I didn't the first time, and when I was done with the day my finger nails made little scratches in the dashboard. I was totally bummed.
Most of all, have a great time. It's very addicting and the most fun I've had for $30.
Alan
Old 06-15-2009, 02:19 PM
CMDR Perry's Avatar
Autox prep
You will need some Big numbers and class letters.
Pack a wet wash cloth in a Ziploc bag and stow it in your cooler for a quick refresh on a hot, dry day.
Use the "force"; Slow in and Fast out. Avoid using the brakes if you can just lift or coast. The strength of a 911 is acceleration out of a corner.
Hit a few cones to get a physical sense of the exterior points of your car.
Have fun and make new friends, remember no beer until after the event.
Old 06-15-2009, 02:43 PM
(the shotguns)
berettafan's Avatar
when you walk the course the second time plan your braking points.
Old 06-15-2009, 06:07 PM
austin552's Avatar
Relax. At first I was really nervous. Everyone gets lost or eats cones. Think of it as a learning experience. Make sure your really into it before getting the racing wheels/tires, etc, etc...
Have fun.
1974 911s
Old 06-15-2009, 06:38 PM
zugelassener benutzer
teamfee3's Avatar
What everyone else said and.....
Oddly enough you'll probably be in second gear the entire time. A lot of courses are fairly small and the 915 doesn't seem to lend it self to getting back into 1st in a hurry, for me anyway. A long course and you might touch third, maybe.
Sunscreen, take all the crap out of your car, and watch what others do in cars like yours. Sideways = slow. Walk the course like you are driving, look ahead for reference points, cones, cars, trees.
1st run, just complete the course, not too slow or you get confused and miss your reference points, 2nd run just try to go a little faster in the place you knew you were too slow, last run go for it a little. 2nd run will probably be your fastest in your first auto-x.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 06-15-2009, 07:16 PM
austin552's Avatar
Originally Posted by teamfee3 View Post
, take all the crap out of your car.
A water bottle can ruin your run.
1974 911s
Old 06-15-2009, 08:00 PM
Immature Member
dentist90's Avatar
As mentioned, pull horn and wiper fuses. It's just embarassing.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-15-2009, 09:23 PM
RETIRED
Joe Bob's Avatar
Catch a ride with the local hot shoe.....bribe him.....get in the 2nd seat, shut up and watch what he does.....
Take your time, go in slow and in control, flog it going out.....NEVER LIFT in a corner.....NEVER say, hold my beer and watch this....never let anyone record that comment or your first time out on the track, never admit this is your first, it may be futile as vets can smell rookies.......unless you wanna give up your man card....
Old 06-15-2009, 09:30 PM
