Home of the Whopper
Fixing a bent strut?
Not sure exactly what happened, but the lower part where the ball joint slips in is bent. So it isnt linear from the top of the strut insert axis to the ball joint axis.
The alignment could probably be set ok when the wheels are straight, but weird things may happen during cornering.
Anybody ever straighten something like this out?
Maybe put a pipe on it, heat it up, and see what happens?
Leave it alone and see what happens?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 03-09-2012, 11:57 AM
RETIRED
Joe Bob's Avatar
I'd take it to an alignment shop that isn't a chain....
2012 ML350 3.0 Turbo Diesel
Old 03-09-2012, 12:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
JB is on top of it. I had a bent strut and Steve Alarcon of Johnson's removed, aligned and re-welded it perfectly
'85 Carrera Targa
PCA/POC
Old 03-09-2012, 12:02 PM
What kind of strut do you have? I bought a complete suspension from somebody a year ago, I refinished the Boge struts, tried to slide my Bilstein inserts in, but couldn't because they were bent. I emailed Chuck Moreland at Elephant Racine about it and he said he couldn't fix them, throw them away. I emailed Clint at Rebel Racing and he said he could definitely fix them, but that was because he had straight Boge tubes laying around.
Old 03-10-2012, 07:52 AM
